will totes be damaged by repeated lifting?
One of our three designs for a lifting mechanism is by lifting under the tote's handle on the SHORT end. (The Ri3d team did this.)
Do we think the totes will hold up if lots of teams do this? Will the lifting handle break? Has anyone experienced failure of the totes from lifting in this way? Any opinions on this will be welcome. |
Re: will totes be damaged by repeated lifting?
Either way if a tote or bin is impossible to use a ref will help with that accoridng to the rules. |
These totes are commercial duty items, they are intended to last for many years to ship product to stores. It is not uncommon to see starters, alternators brake calipers and other heavy items shipped to auto part stores in them. So 50-75lbs is not uncommon. So I don't think that we will see that many damaged by lifting by the handle.
We have cracked a tote by tipping a stack over. It still functions but it isn't as strong as it was.
I don't believe that lifting will cause issues, but when a six high stack is knocked over by an over-zealous driver ... I suspect that TOTES (and RECYCLE CONTAINERS) will be damaged and that teams will have to make their lifts accommodate for these imperfections. |
The rulebook has a rule about it being your drive team's responsibility to notice and complain about broken/imperfect game pieces. So I'd recommend that while you're waiting in pre-match queuing, keep a very close eye on the totes on your side of the field, and point broken ones out to the ref.
I think lifting the totes by the handle will not break the totes much, there will be exceptions of coarse. What worries me more is teams running into the totes with the corner of there robot that does not have bumpers. Those sharp corners will break the totes pretty easy in my mind. Once that happens, what is the structural integrity of the tote going to be like?
