Go to Post It's about compressing life into 6 weeks. It's about doing. It's about learning to fail. It's about gracious professionalism. It's about releasing the limitations that we all put on ourselves. It's about thinking outside of the box. It's about growing. - JohnBoucher [more]
Unread 12-01-2015, 00:08
aspadiyath aspadiyath is offline
FRC #3206
aspadiyath is an unknown quantity at this point
Boolean Help?
So I was harmlessly programming, when one of our drivers requested that when he presses a button, the indicator should show true. Then after he's pressed it once, it should stay true until he presses the same button again, making it false.
I know this is possible, but how?
Thanks!
Unread 12-01-2015, 00:11
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Boolean Help?
I know this is possible, but how?!
https://www.google.com/?gws_rd=ssl#q...m+latch+button
https://www.google.com/?gws_rd=ssl#q...+button+toggle
Unread 12-01-2015, 00:31
FRC #3206
Re: Boolean Help?
How do I get the latch without a while loop?
Unread 12-01-2015, 01:05
Team118Joseph's Avatar
Team118Joseph Team118Joseph is offline
The guy that did the lighting
AKA: Joseph Foster
FRC #0118 (Robonauts)
Rookie Year: 2013
Team118Joseph will become famous soon enoughTeam118Joseph will become famous soon enough
Re: Boolean Help?
So he wants it to toggle? If so you will need 2 bools. One will store the current mode state and the other will store the last state of the button. If the button is true, it will check the the last state of the button. If the last state is false, change the state of the mode.
Here is an example in C++
Code:
//this code is in the class header
bool pressed;
bool value;
//this code is in the initializer
pressed = false;//saves the button press
value = false;//what ever is being toggled
//this code is in the periodic thread
if(joystick->GetRawButton(1))//gets the button value and checks if it is true
	if(pressed == false)//Checks if the last button state was false
		value = !value; //flips the value
	pressed = true;//saves the buttons state
else//if the button is not pressed
	pressed = false;//saves the buttons state
I know its not LabView but the concept should be the same.
FRC Countdown Website: http://frccountdown.hosthorde.net/
FRC Countdowns App: https://play.google.com/store/apps/d...h.frccountdown
Last edited by Team118Joseph : 12-01-2015 at 01:16. Reason: added comments to the code
Unread 12-01-2015, 07:24
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Rookie Year: 2010
adciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to all
Re: Boolean Help?
We have this VI in our programming library, available from this thread
http://www.chiefdelphi.com/forums/sh...d.php?t=131783
I believe it's under 'logic'.
Originally Posted by texarkana View Post
I would not want the task of devising a system that 50,000 very smart people try to outwit.
Unread 12-01-2015, 10:14
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Boolean Help?
One way, except note that buttons are now (2015) retrieved from an array.
