Number of Pneumatic Air Tanks
My team does not have much experience with pneumatics and this year we are planning to have pneumatics play a major part in our robots function. We are planning on using four 5/16" bore and 14" stroke single action (spring return) that will open and close up to 25 time but let's say 50 times to be safe. Also there will be another smaller cyllender of unknown bore but about 5" stroke dual action and would probably only open and close 5 times. We would also have the standard Viair compressor. We were thinking 6 of these tanks (http://www.andymark.com/product-p/am-2649.htm) pressurized at 120psi. Do you think that will be sufficient?
Re: Number of Pneumatic Air Tanks
I like to use Paul Copioli's Useful Calculations spreadsheet for this. The only thing is that it doesn't factor in the compressor flow rate.
Last edited by Mike Marandola : 01-13-2015 at 09:30 AM. Reason: Removed misleading information |
My general feeling this year is that it's probably going to work OK to use pneumatic stuff to "grab", but not to "lift". If you try to do too much work with pneumatics, you run out of air pressure, and the compressor can't keep up.
By the combined gas law the quantity (P*V)/T remains constant throughout a closed system in steady state. If we can also assume that the temperature of the system remains approximately constant over the duration of interest, then the quantity P*V remains approximately constant too.
P*V ≈ constant This is a pretty powerful tool. We can use it to equate the energies of two different volumes of gas at two different pressures. P1*V1 ≈ constant ≈ P2*V2 P1*V1 ≈ P2*V2 The quantity P*V will be in units of energy. This number will in fact be a estimate of how much stored energy is contained in the pressurized system. (But it's not quite a measure of how much energy is available in the system to do useful work!) Here's an example. First let's look at how much energy is contained by the storage tanks. P1 = 120 psig storage pressure V1 = two 16 in^3 tanks = 32 in^3 P1*V1 = (120 psig)(32 in^3) = 3840 in*lbf Now, how many times can you use that energy to actuate an example cylinder? P2 = 60 psig point-of-use pressure V2 = (n actuations)(5/16 in bore x 18 in stroke) = n(.0767 in^2)(18 in) = n(1.38 in^3) P2*V2 = n(60 psig)(1.38 in^3) = n(82.8 in*lbf) P1*V1 = P2*V2 3840 in*lbf = n(82.8 in*lbf) Solve for n... n = 46 actuations Last edited by Nate Laverdure : 01-12-2015 at 04:16 PM. Reason: Thanks for the correction Jon! |
Depending on what you want to be doing with your pnuematic cylinder you may want to rethink/recalculate what you want to use. I've found this calculator very quick and useful. http://www.pneumaticsonline.com/calc2.asp
If you plan on picking up more than one tote, you'll probably need a much larger bore. This is assuming you want to use pnuematics to pickup totes of course. Also you may want to take a look here http://www.chiefdelphi.com/forums/sh...anks+exploding This was last year and I don't know if they've changed the tanks at all. Last edited by John Retkowski : 01-12-2015 at 03:08 PM. |
Does it take into account what happens when storage pressure drops below 60 PSI, it does it assume you can go down to 0 psi storage while maintaining 60 psi working? When your storage drops below 60 PSI, the equations have to change a bit, as you can no longer have the desired working pressure. Perhaps a better approach would be to do the math from the other direction - what volume of your stored air (at 120 psi) would be needed for a single actuation (at 60 psi)? Since we know PV is roughly a constant, we know we have roughly half our total storage volume available to us before we drop below 60 psi storage. If it takes 2% of the total storage volume for one actuation, then we would get 25 actuations before dropping below 60 psi, for example. |
5/16" bore cylinders are really small! they will only produce a few pounds of force. But they won't use much air.
I'm just trying to make sure I understand the math right so I can guide. my kids through it later when we need to do it... I don't want some mistake or something forgotten in the 10 years since I last really used this stuff to screw up my team! |
Oops, my team had been looking at 18" stroke, I just have transposed it to this discussion by mistake. Thanks for the help!
#11
Sure, also, don't forget that the pushing on a cylinder is greater than the pulling force because of the rod (you lose usable surface area). It's generally not that much, but it can bite you if you're borderline.
#12
This was especially important if a robot used a lot of air with a lower storage volume, as the compressor would start to re-fill the tanks when they were already close to full, thus not re-filling the tanks at the 0.88cfm rate. Back in the day, we weren't allowed unlimited air tanks - so maybe these days that performance hit isn't as big a deal. Last edited by JesseK : 01-12-2015 at 04:43 PM. Reason: Actual data on performance is below. |
#13
Was hoping you'd look more at the thermodynamic concept at the beginning of my post, not the geometry at the end. |
#14
This is the killer. Many compressor spec sheets list CFM at a few different pressures, and you'll see with small compressors like the ones we can use, the difference in flow between 0 PSI and 60 PSI is substantial. As is the difference between 60 PSI and 120 PSI.
#15
PSI CFM 0 0.88 10 0.71 20 0.67 30 0.64 40 0.60 50 0.57 60 0.53 70 0.48 80 0.45 90 0.43 100 0.39 110 0.36 120 0.34 Numbers pulled right off their website. |
