Go to Post And those who DO know won't talk, even for Krispy Kremes. - DonRotolo [more]
Unread 12-01-2015, 19:42
Gary Suter Gary Suter is offline
FRC #2439
Gary Suter is an unknown quantity at this point
Wiring 12 Motors
We want to use 12 motors (4 - MiniCims, 4 - Cims, and 4 - BaneBot 755) for this years robot. However we have not used this many before and not sure where to wire them all because there is only 8 ports in the PDB for 40 Amp.
Can we use the 30 Amp ports to wire? Also we are using talons for our motor controllers.
Unread 12-01-2015, 19:48
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Wiring 12 Motors
While you can use the 30A fuses, just make sure your applications don't draw more than 30A.
Also, 12 motors is a lot. Expect heavy battery drain! Also be aware of what happens to motor outputs when the roboRIO drops below a certain voltage.
Edit: Also check rule R37 and R38 for proper wire gauge and motor controller rules.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 12-01-2015, 20:18
FRC #2439
Thanks for the help.
