Go to Post We can't be afraid to critique the existing system. If we don't, how will it ever get better? - Jaine Perotti [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 12-01-2015, 20:20
GabrielKB GabrielKB is offline
FRC #0919 (Tiger Techs)
Team Role: Leadership
Rookie Year: 2013
GabrielKB is an unknown quantity at this point
Unstable AM14U2 Chassis
As the title implies, our 2015 KOP drivetrain is somewhat unstable. This is due to the fact that the center wheels are about 0.6 cm below the other wheels, causing one end to be 1cm off the ground when the other is touching. During assembly this was noticed and attributed to the different wheels we chose for middle and sides, but once we changed them all to uniform 6" wheels we realized that the axles are at different heights.
Is this an intentional part of the design or did we just horribly mess up? If it's intentional what is its purpose? If not, has anyone else encountered this or has an idea of our mistake?
When flipped over the top of the gearbox and the two outer wheels form a stable plane and the difference in height on the middle wheel becomes obvious:
http://i.imgur.com/z3tI1Sy.jpg?1
The CAD model provided by Andymark seems to have the middle wheels 0.35 cm below the others, but that still isn't close to this height.
Unread 12-01-2015, 20:21
JorgeReyes JorgeReyes is offline
Team Captain
FRC #2002 (Tualatin Robotics)
JorgeReyes is an unknown quantity at this point
Re: Unstable AM14U2 Chassis
Center wheels are dropped so that the robot could turn easier
Unread 12-01-2015, 20:23
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
FRC #0461 (Westside Boiler Invasion)
Team Role: Coach
Peyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond repute
What you are describing is a drop center and it is intentional. This allows for a smoother turn.
461 Westside Boiler Invasion
2016 Tippy Quarter finalist, Warren Finalist, IN State Semi Finalist,B^3 Double Finalist
2015 Indy Semi finalist, Purdue Quarter Finalist, IN State Quarter Finalist, CORI QF, R2OC Finalist, RAGE Winner
2014 Boilermaker Semi finalist, Crossroads Quarter Finalist, & CAGE Quarter Finalist
45 Technokats
2013 Boilermaker Quarter finalist
2012 CAGE Semi finalist & Queen City Champion
2011 CAGE Quarter finalist & Midwest Semi finalist
2010 CAGE Quarter finalist, Boilermaker Champion, & Washington DC Quarter Finalist
Unread 12-01-2015, 20:27
EricH's Avatar
EricH EricH is online now
New year, new team
FRC #1197 (Torbots)
To expand further, what you're seeing is known as a 6WD drop center drivetrain. The center wheel is dropped for easier turning; effectively the robot's wheelbase is cut in half. Incidentally, this is THE most common general drivetrain setup in FRC, at least the last 5-10 years or so. (8WD drop center is close.)
Here's an exercise if you're interested: Drive the robot without the middle wheels being installed at all. Then drive it with the middle wheels. You should see a difference.
Now, how to cope with the drop/rock: You'll probably want to put all your heavy items on one end. This would be the battery, the high-pressure side of the pneumatic system, and some if not all of the control system. That should hold that end down, giving the robot more stability.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 12-01-2015, 23:41
Rookie Year: 2013
Thanks for the replies! Last year's didn't have this so I was unfamiliar, and wasn't sure what exactly to search up. The whole reason we were trying to have different center wheels was to allow for better turning, but I guess that's already been made easier. Learn new things every day!
Unread 13-01-2015, 00:12
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
As I described in my drivetrain class at our "robocamp" [mostly] for the incoming freshmen this summer -- the drop-center tank drive train gives the advantages of a short wheelbase for turning, and the advantages of a long wheelbase for stability (which I defined as not falling over in a hard acceleration or brake).
