Go to Post FIRST is nothing short of a community. - karinka13 [more]
Unread 01-13-2015, 04:38 PM
karanesu karanesu is offline
AKA: Emily
FRC #4610 (BearTecs)
Rookie Year: 2014
karanesu has a spectacular aura aboutkaranesu has a spectacular aura about
Wrong JDK version?
After installing Eclipse to use with RobotBuilder, I tried to set up the JDK to use with Java. I installed the Java development tools, but I seem to have the wrong version of the JDK. I appear to have JDK 7, but I saw that it should say 1.8 or 8. Will this pose a significant problem with using RobotBuilder to code our robot? If it does cause an issue, how can I fix it?
Unread 01-13-2015, 10:32 PM
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
Rookie Year: 2010
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
Re: Wrong JDK version?
This shouldn't cause any issues with RobotBuilder, but if you try to run the Java Installer for the roboRio, it will fail. Other than that, you shouldn't run into any issues, you just won't have access to some of the cool new features in Java 8.
Unread 01-14-2015, 01:33 PM
krieck's Avatar
krieck krieck is offline
AKA: Keith
FRC #2846 (Firebears)
Rookie Year: 2012
krieck is an unknown quantity at this point
You should install Java 8 if you want to use the Riolog to view console output from the robot.
