Go to Post Ya know...sometimes, design specs get changed at the last second. Or the market changes while you weren't watching. It Happens. - DonRotolo [more]
Unread 13-01-2015, 19:29
tmk tmk is offline
FRC #0876
tmk is an unknown quantity at this point
Exclamation Pneumatics Problem
Our test robot has a double action solenoid on it. I wanted button 3 on the right joystick to make it go both out and in. But currently, button 3 is making it go out and button 4 is making it go in. (Even though button 4 is not wired to the solenoid.) In fact, I completely deleted button 4 from the program, and it still controlled the solenoid. Buttons that don't exist in the program shouldn't work when I run it! I also tried creating an imaginary motor (one that doesn't exist on the robot) for button 4 to control, just to give it something to do, but it still controls the solenoid.
Any help is very, very welcome.
Unread 13-01-2015, 19:38
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Pneumatics Problem
That sounds like your updated code isn't getting onto the roboRIO.
Are you using Run or are you doing a Build/Run as startup?
If you open Robot Main.vi is the white Run arrow solid or broken?
Do you get any error messages when you Build?
Any error messages when you Run as startup?
Unread 13-01-2015, 20:20
tmk tmk is offline
FRC #0876
I'm using Run as Startup, and on the robot main.vi the white arrow is solid. It builds and runs perfectly, but when I try to control the robot with the joysticks I get that problem with the button.
Unread 13-01-2015, 20:48
Just Itinerant
If you hit the Reset button on the roboRIO (or cycle the robot power) does button 4 still misbehave?
Unread 13-01-2015, 21:26
tmk tmk is offline
FRC #0876
AGGGGHHH! It was so glaringly obvious!
I built the program the first couple of times, but when I was changing things I forgot to re-build the program every time I changed something in the program.
How could I forget something like that?!
Thanks for trying to help. I think it'll work now.
Unread 13-01-2015, 21:42
Just Itinerant
Good luck!
Unread 21-01-2015, 18:56
cougarbot cougarbot is offline
FRC #2665
cougarbot is an unknown quantity at this point
We are trying to wire a bimba MRS-.087-B. The wire coming from the roboCRIO has 3 wires (red,white,black) but the bimba MRS switch has a black and red wire. Can someone help us wire it?
Unread 21-01-2015, 19:03
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
The red wire (assuming it's in the center) provides 5V. The switch doesn't need power since it's a passive switch. Connect red to white and black to black (you could actually switch them if you wanted), cover up the red wire so it can't touch anything and you should be all set.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 06-02-2015, 18:47
Jack Gillespie's Avatar
Jack Gillespie Jack Gillespie is offline
FRC #5430 (Pirate Robolution)
Team Role: Teacher
Jack Gillespie is an unknown quantity at this point
Can you share your code for button 3 out, button 4 retract. That is exactly what we are trying to do. We are close but something is not right
Team 5430,
What a bunch of rookies
Unread 06-02-2015, 19:13
Just Itinerant
Does this Double Solenoid example help at all?
There are two examples in this, a Single Solenoid to the left and a Double Solenoid to the right. You're probably only concerned with the Double example.
