Go to Post "We put the eek in Geek" - Wayne Doenges [more]
Unread 14-01-2015, 08:10
jfitz0807 jfitz0807 is offline
FRC #2877 (Ligerbots)
Team Role: Parent
jfitz0807 is an unknown quantity at this point
CANTalon not in RobotBuilder?
We've used CANJaguars the last couple of years. This year, of course, we're switching to the CANTalon with Talon SRXs. The RobotBuilder (RB) doesn't seem to have an option for a CANTalon.
Can I just instantiate a CANJaguar in RB and change these to CANTalon in RB before I generate my code? This seems preferable since it would be maintained through subsequent code regenerations. The only other option I can think of is to generate the code with CANJaguar and then do a global search/replace to change CANJaguar to CANTalon in Eclipse, but then I'd have to do this every time I regenerate code.
Any thoughts?
Unread 14-01-2015, 20:52
krieck's Avatar
krieck krieck is offline
AKA: Keith
FRC #2846 (Firebears)
Rookie Year: 2012
krieck is an unknown quantity at this point
Re: CANTalon not in RobotBuilder?
We also ran into this problem. For now, I think the only solution is to generate code for plain Talons and then edit the init() method in RobotMap. Change the Talon constructors to CANTalon and then delete the "AUTOGENERATED" comments.
It would sure be nice to get an updated RobotBuilder supporting CANTalons. Also, it would be nice if the CANTalon class was updated to implement LiveWindowSendable, so we could see the CANTalons in test mode.
Unread 14-01-2015, 21:57
Jefferson Jefferson is offline
AKA: Jeff Clements
FRC #0016 (Bomb Squad)
Rookie Year: 2010
Jefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant future
This bug has been reported. It wouldn't surprise me if we get a WPILib update at some point this season.
Unread 25-01-2015, 15:59
jmullins16's Avatar
jmullins16 jmullins16 is offline
AKA: Jeff Mullins
FRC #2135 (Presentation Invasion)
Rookie Year: 2011
jmullins16 is an unknown quantity at this point
A solution involving a patch to the RobotBuilder sources is described in this post:
http://www.chiefdelphi.com/forums/sh...04&postcount=5
