Go to Post The most amazing and inspiring character I've met in FIRST, Wayne [Cokeley] has definately shown me the character of a true leader. - Bharat Nain [more]
Unread 14-01-2015, 11:04
rod@3711 rod@3711 is offline
AKA: rod nelson
FRC #3711 (Iron Mustangs)
Rookie Year: 2014
rod@3711 is an unknown quantity at this point
Running Robot Builder directly from Eclipse C++
We can not run WPILib commands directly from Eclipse C++ using the WPLIB menu. Nothing happens when we select Robot Builder.
We can run Robot Builder directly, them import the results into Eclipse, then build and deploy.
We can live with it, but it only happens on one computer. Our other computer works as expected.
I read Chief Delphi posts a lot, but this is my first post. It is so exciting...
Unread 14-01-2015, 16:54
jfitz0807 jfitz0807 is offline
FRC #2877 (Ligerbots)
Team Role: Parent
jfitz0807 is an unknown quantity at this point
Re: Running Robot Builder directly from Eclipse C++
We've been having lots of issues setting up Eclipse. It works on some computers but not others.
Sorry I can't be of more help other than to let you know that you are not alone.
Unread 14-01-2015, 17:58
cbf cbf is offline
FRC #2877
cbf is just really nicecbf is just really nicecbf is just really nicecbf is just really nicecbf is just really nice
Yes, the WPILib menu in Eclipse seems to be broken on most, but not all, of the computers we've set up.
The whole process of setting up Eclipse and installing the FRC tools seems overly complex and error-prone. Particularly the part about the FRC toolchain source (FRC Windows Toolchain 4.9.1-0build1.msi) needing to be run from the same drive that Eclipse is installed on.
