Go to Post I want my students to learn passion. I want them to care so much about what they are doing that they infect other people with it... be that FRC or anything else. - marshall [more]
Unread 14-01-2015, 15:37
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
Taking your robot to the field
From the 1/13/14 game update:
While there is no corresponding change to the Game Manual, the LRI’s also wanted to make sure that all teams are aware that ROBOTs must fit in, and be transported in, a single
TRANSPORT CONFIGURATION volume at the event. This doesn’t mean the exact configuration of the robot within that volume must be the same every time, but that every time
a team is moving their robot as required under T6, they must do so using only one contiguous volume of the size and orientation specified
I am not sure how rigorously this will be enforced, but. This means if you have detachable arms or a mast, you cannot have some one carry a piece separate from the robot. It will all have to be in the robot transport volume. Safe transport will mean designing the robot so the detached pieces are not precariously crammed into the transport volume. It will make for some interesting maneuvers if it is required from the field to the cart.
If you don't know what you should hook up then you should read a data sheet
