Go to Post We did the best job we could out there, and unfortunatly we have human limits.. The refs don't catch every penalty, inspectors don't catch every issue, and this year the score keepers won't catch every single ball. - nobrakes8 [more]
Unread 14-01-2015, 18:42
Potatonator's Avatar
Potatonator Potatonator is offline
much potato very robot wow
FRC #4360 (Spudnik)
Rookie Year: 2012
Potatonator is an unknown quantity at this point
Motors randomly stopped working
Last Saturday we got our kit of parts, which included two motors. Those motors worked perfectly fine when we manually turned them then for testing. After testing them, we built them into gearboxes, and then stored them in a box with other parts. Today (Wednesday, four days later), we took out the motors again, and they could barely turn at all. Nothing about them has been modified, aside from putting them in the gearboxes. Any ideas what our issue could be?
Thanks in advance =D
EDIT: Fixed a wording error.
Unread 14-01-2015, 18:45
sergioCorral842's Avatar
sergioCorral842 sergioCorral842 is offline
College Student
FRC #0842 (Falcon Robotics)
Rookie Year: 2012
sergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to behold
Re: Motors randomly stopped working
Pictures of the setup (wiring, etc) will be useful for people to determine the problem.
Team 842 Falcon Robotics: 2011-2015 (President, Head Programmer, Drive Team)
Arizona Regional Winners: 2012-2014 (Thanks 610, 1212, 1726, 3944, 2486, 2403)
Curie Division Semi-Finalists: 2014 (Thanks 1311, 2013, 2928)
Las Vegas Semi-Finalists: 2015 (Thanks 3495, 4415)
Curie Division Quarter-Finalists: 2015 (Thanks 107, 228, 649)
2015 - 2016: Programming, Drive Team, and Strategy Mentor for Team 3187, The Titans
Studying Computer Science- Software Engineering at ASU (Class of 2019)
Unread 14-01-2015, 18:48
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
If you take the motor OUT of the gearbox, and connect it directly to a battery (assuming it is a 12V motor and safe to do so), does the motor turn?
If so, then the problem is in your gearbox. Is your gearbox assembled correctly? Did you grease the gears?
Is the gearbox designed to turn slowly?
Edit: I'm assuming the gearbox is NOT the gearbox provided in the KoP for the kitbot. If it is, then disregard the last question.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 14-01-2015, 18:51
FRC #4360 (Spudnik)
Rookie Year: 2012
Oh, I worded the question badly. We haven't actually wired the motors up and run them, we just cranked them by hand to test them. So the issue is just that today, it was much harder to turn. Sorry for my mistake, I'll fix it quick.
Unread 14-01-2015, 18:53
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
I would recommend that you test the motors first.
Also, how were you cranking the motor by hand, when it was in the gearbox? Are you attempting to turn the output shaft by hand?
1771- Mentor (2015)
Unread 14-01-2015, 19:01
FRC #4360 (Spudnik)
Rookie Year: 2012
After doing what you said and testing it with a battery, it *seems* to run fine.
So today we learned that we need to test stuff before we panicked. Thanks to the people who stopped by to help us with our non-problem =D
Unread 14-01-2015, 19:49
FTC5110 FTC5110 is offline
FTC #5110 (Wingus & Dingus)
FTC5110 is a splendid one to beholdFTC5110 is a splendid one to beholdFTC5110 is a splendid one to beholdFTC5110 is a splendid one to beholdFTC5110 is a splendid one to beholdFTC5110 is a splendid one to behold
If you accidentally had the motor wires shorted together the shaft would become much harder to turn by hand. Perhaps that's what happend.
Permanent magnet brushed DC motors are also DC generators.
Unread 14-01-2015, 19:56
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
Team Role: Coach
Rookie Year: 2010
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
The motor will be considerably harder to turn because you are now turning the gearbox as well. Compound that with the fact that you are trying to turn a small output shaft to rotate a gear set designed to increase torque in the opposite direction to turn the motor means that you are fighting the laws of physics in a way that will cause you to use more effort to get the job done.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
