Go to Post 1902...hmmmmm did it go oink oink boom when it blew up? - Rohith Surampudi [more]
Unread 14-01-2015, 19:23
SeanFitz's Avatar
SeanFitz SeanFitz is offline
1st Year Mentor
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2010
SeanFitz is a glorious beacon of lightSeanFitz is a glorious beacon of lightSeanFitz is a glorious beacon of lightSeanFitz is a glorious beacon of lightSeanFitz is a glorious beacon of lightSeanFitz is a glorious beacon of light
Changing Gearboxes
So our team spent most of the off season perfecting a 6-CIM, 2 Speed drivetrain system (see how well that worked out? ) using these.
Anyways, we are in the process of trying to find a better gearbox, preferably single speed. At the moment, our preferred choice is this.
The problem we keep running into is that we are using the VEX Versa Chassis and have no way of connecting the single speed gearboxes to it. Does anyone know of a way to do this? Or should we just stick with what we have?
Thanks
"A good driver always beats a good robot"
2015: 2 Chairman's Awards, 1 Finalist Medal, 1 St. Louis Alliance Captain Hat (7th Seed Newton)
2014: 1 Blue Banner, 1 Finalist Medal, 1 Amazing time in St. Louis.
Unread 14-01-2015, 20:07
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Re: Changing Gearboxes
I feel like there's a way to connect those gearboxes, as they are Vex products after all.
We're in a very similar situation, and we decided to go with the clamp-on gearboxes with a sprocket reduction to the wheel.
Unread 15-01-2015, 09:36
Paul Copioli's Avatar Unsung FIRST Hero Woodie Flowers Award
Paul Copioli Paul Copioli is offline
President, VEX Robotics, Inc.
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2000
Paul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond repute
Thanks
If you already have the Ball shifter you can simply lock the shifter into one of the two speeds. The ball shifter will work fine as a single speed gearbox if you do this.
Alternatively, you can purchase the WCP SS gearbox: http://www.vexrobotics.com/vexpro/mo...es/wcp-ss.html
Paul
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 19-01-2015, 09:53
PowerfulKitty PowerfulKitty is offline
Drive Coach
AKA: Alex Dalziel
FRC #5576 (Team Terminator)
Team Role: Driver
PowerfulKitty will become famous soon enough
If you are going to direct drive one wheel with this gearbox, all you have to do is line up the shaft using bearings on your bearing hole. There are two holes that are slightly higher than the center of the shaft hole (by like 1/8") on either side of it. Hold or clamp the box in place, use a transfer punch (or drill bit if you don't have one) that is 1/4 inch in diameter to mark on the versaframe where the centers are, and drill it. Two bolts like this will hold it well.
