Compressor and No Selenoid
We are using pneumatics for the first time this year. Since I wasn't around for this teams rookie year things got lost. I had to round up all the pneumatics parts I could find.
I didn't do well. The brass fitting were gone so we ordered more of them and now we have plenty. After a day or two of rummaging I found the air connectors for the double solenoid. But I couldn't find the side clips for it and had to order them. Consequently I can't wire the solenoid to the PCM. What I was going to do today was check the compressor and the air system for leaks. But without the solenoid the PCM just blinks red. I don't see any way around this and will probably have to wait for the clips. I tried to add some compressor code but this won't work since the PCM is not in a ready state. |
Re: Compressor and No Selenoid
The PCM is controlled via CAN. So make sure you daisy chained a CAN cable from the rRIO to the PCM and then to the PDP. You can force the compressor to start without a solenoid by creating a compressor in the code and then setting closed loop control to true.
The PCM blinking red is the No CAN Comm. and not a solenoid fault as I had first thought. From this document I can see the diagram at the top shows where CAN connects. But from the rest of the document they don't really emphasize it in any picture. Has anyone else been confused by this? https://wpilib.screenstepslive.com/s...he-2015-system |
Look here about halfway down or search for PCM.
It demonstrates the CAN wiring. https://wpilib.screenstepslive.com/s...control-system |
This was a much better reference page. Mailed link to myself. Thanks!
