Re: pic: Bit Buckets 2015 Prototype Drive Pod
Exactly what wood are you burning with your laser. I say exactly because I have access to a 160 watt laser and have tried cutting 1/4 Baltic birch and if it will cut depends on where I get it.
Some cuts real nice and some will only seem to cut to the glue line then just starts burning. So, if you have any details on what you are using it would be appreciated. Thanks |
Yes it will cut an inch of pine but not some plywoods.
I think a killough actually has a root2 speed up.
I hadn't put much thought into it, but I believe you are correct. Those modules will probably need another reduction stage.
.25" 5-ply Baltic Birch plyood from Woodworkers Source. |
Assume constant power output P. P = force * velocity (dot product used here). Since the force of the wheel along the direction of motion is effectively reduced by a factor of 1/sqrt(2), the velocity must increase by a factor of sqrt(2) to maintain that power output. |
I remember reading your laser cutter is 29x17", but how powerful is it?
