Go to Post It sounded like a good idea, and then I thought about it. :-/ - Wetzel [more]
Unread 15-01-2015, 16:35
VD3626 VD3626 is offline
FRC #3626
VD3626 is an unknown quantity at this point
Compressor not starting
This is the code I have been using to try and get the compressor to run. The test motor is there just to tell me whether or not the compressor is getting the message to start or not. The motor runs no matter what I try to change which is strange because I am setting "SetClosedLoopControl" to true yet it does not seem to change to true.
Code:
void AutonomousCommand::Execute() {
	compOneCompressorOne->SetClosedLoopControl(true);
			if(compOneCompressorOne->GetClosedLoopControl() == false)
				Robot::testMotor->Go();
Any help is appreciated.
Unread 15-01-2015, 22:59
MHSrobotics2853's Avatar
MHSrobotics2853 MHSrobotics2853 is offline
Mililani Robotics
FRC #2853 (Trobobots)
MHSrobotics2853 is just really niceMHSrobotics2853 is just really niceMHSrobotics2853 is just really niceMHSrobotics2853 is just really niceMHSrobotics2853 is just really nice
Re: Compressor not starting
You have to "Start" the Compressor class. It's a function of the class.
http://first.wpi.edu/FRC/roborio/dev...ompressor.html
Ah, my bad, forgot it was enabled by default. See response below vvvv
Unread 15-01-2015, 23:00
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
I'm pretty sure the compressor isn't enabled until you have defined at least one pneumatic solenoid. And it's enabled by default; you don't have to explicitly turn on closed loop control. You only have to worry about it if you ever want to disable it.
