Go to Post you know the FIRST season is never over . . it just pauses a while so you can get some sleep. - Stuart [more]
Unread 15-01-2015, 17:33
Awesomegamer235 Awesomegamer235 is offline
None #4607
Awesomegamer235 is an unknown quantity at this point
HELP!
is there any tutorials on the new java??
Unread 15-01-2015, 17:36
bobjones227's Avatar
bobjones227 bobjones227 is offline
AKA: Henry Bray
FRC #2512 (Daredevils)
Team Role: Tactician
Rookie Year: 2014
bobjones227 is on a distinguished road
Re: HELP!
I personally don't know anything about programming, but you could check the internet if you haven't yet. Here, let me help.
http://lmgtfy.com/?q=java+tutorials
"When I say Admiral, you say Ackbar!"
"Admiral!"
"IT'S A TRAP!"
2015 Northern Lights Regional Finalists
2015 Central Illinois Regional Finalists
2015 Einstein FinalistsThanks to our great alliance of teams 987, 2826, and 4265!
2015 MN State Champions Working with the fantastic teams 3130 and 4215!
Unread 15-01-2015, 18:49
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Rookie Year: 2007
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Re: HELP!
What about the new Java?
Are you looking for documentation on the WPI Library APIs that we use in FRC? If so, all of the previous documentation is more or less applicable- those haven't changed much at all.
If you are looking for documentation on new features that we get by switching to Java 8 SE, then I would recommend starting with the Java 8 release notes from Oracle. You will also want to search for the Java 7, Java 6, and Java 5 release notes. You can also find an countless number of tutorials, guides, and tips for Java 5-8 online.
Team 2052- Knightkrawler
Mentor and volunteer
Unread 15-01-2015, 19:25
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Rookie Year: 2012
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Re: HELP!
Try looking at my teams example drive train code here
Unread 16-01-2015, 01:45
Lloydpro Lloydpro is offline
AKA: Jacob Beeman
FRC #3495 (Mindcraft)
Rookie Year: 2014
Lloydpro is an unknown quantity at this point
Re: HELP!
I'm very curious why you have like 4 classes just for drivetrain? I just make a quick method and it's over with. Nothing too fancy unless it has to be. In fact I don't know why people make othe classes for stuff when coding for FRC. If you are willing to enlighten me I would be very interested to know why you do that!
Unread 16-01-2015, 03:01
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
Re: HELP!
I can't comment on this specific case, but by using independent classes, the code can be developed by multiple groups who don't know anything about the code another group is working on. When the final code is written, the only information needed is the names, functions, and arguments of relevant methods for each operations that is to be performed.
In general, breaking up code like this can be helpful since it helps keep issues isolated. If something needs to be rewritten, it is probably going to be limited to one class instead of the entirety of the project.
Unread 16-01-2015, 07:39
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
Re: HELP!
It also makes the code more readable, which is the key to programming.
Unread 17-01-2015, 10:10
Head programmer
Rookie Year: 2012
Re: HELP!
Well, I'm my specific case It is just me working on our code. So I programmed for every possible drive train except swereve because my team doesn't know what their doing for a drive train, we have had talks of all of them...I'm going to update my github repositories today and that code has examples for all the drive possible except swerve. Most of them are not fully tested.
Unread 19-01-2015, 16:48
None #4607
Re: HELP!
what is the "package org.usfirst.frc.team3019.robot.subsystems;" mean
Unread 19-01-2015, 18:44
Head programmer
Rookie Year: 2012
Re: HELP!
This is the auto generated package for a command based robot. There are 3 different packages auto created. robot.subsystems, robot.commands, and just robot.
explanation of each package:
Robot.Subsystem: This package contains classes to hold motor instances, sensors, pnumatics. In each class there are also methods to move each motor and read the sensors.
Robot.Commands: This package contains the classes that tell the subsystems how to act. For example the class DriveStraight class tells the driveTrain subsystem to drive untill X condition happens.
Robot: This package contains the 3 main classes: Robot, RobotMap, OI
  • Robot: This is the main class of the Robot, instantiates all the public static subsystems and sets the autonomous command.
  • RobotMap:Holds all the constants of the Robot so there is not a bunch of magic numbers in the code, generally using a single class for all constants is bad practice, however use it for now.
  • OI:Holds the joysticks and the joystick buttons and binds the buttons to the commands
Unread 19-01-2015, 19:09
Nickman4456 Nickman4456 is offline
FRC #4456 (Mech Cadets)
Rookie Year: 2014
Nickman4456 is an unknown quantity at this point
Re: HELP!
Since this is an article about getting help, I wanted to ask how to begin a thread on chief delphi. I might just be completely overlooking something, but I don't know how to ask questions on this site. If anybody could give an answer, that would be of great help. Thanks
Unread 19-01-2015, 21:40
TFleig78's Avatar
TFleig78 TFleig78 is offline
AKA: Tyler
FRC #0078 (Air Strike)
Rookie Year: 2012
TFleig78 will become famous soon enoughTFleig78 will become famous soon enough
Re: HELP!
On the top left, click on forums, then go to a specific forum, for example, programming. Then above all of the threads, there's a blue button that says "new thread."
