Go to Post There are laws of physics, useful rules of thumb, and cold hard economics that come into play to be sure but at it's core Engineering is Art. For these artists, there is no substute for the sound engineering judgement. - Joe Johnson [more]
Unread 15-01-2015, 17:49
emmavanh emmavanh is offline
FRC #0384
emmavanh is an unknown quantity at this point
roboRIO imaging to incorrect IP
Hey guys,
We're having an issue with the roboRIO imaging tool. When we re-image the roboRIO, it is re-imaged to an IP Address of 169.254.210.59. However, we know that it should be re-imaged to an IP Address of 172.22.11.2.. We can communicate with the roboRIO through Internet Explorer, pinging, and deploying code, but communications are not being shown in the Driver Station Tab.
Any suggestions on how to fix it?
Unread 15-01-2015, 18:03
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: roboRIO imaging to incorrect IP
The roboRIO has two IP addresses.
The 172.22.11.2 is only for the USB connection.
Hook up an A/B USB cable between the laptop and the roboRIO to use this.
What you have for an Ethernet address is sort of a default value.
For the roboRIO to get an appropriate Ethernet address it needs to be connected to a DLink that has been setup with this year's Bridge Configuration Utility.
Unread 15-01-2015, 18:13
FRC #0384
Thank you very much!
Unread 15-01-2015, 20:52
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
Thanks again! Do you know why the driver station might not see it though? We're running v15.0, and we can deploy code and ping the roborio, but the DS says no connection. Any ideas why?
"Measure with a micrometer, mark with chalk, cut with an axe."
Unread 15-01-2015, 21:45
Just Itinerant
The DLink assigns compatible IP addresses/netmasks to both the roboRIO and the Driver Station laptop. If they are mismatched, then that may be the cause of the Driver Station not connecting to the Comm task on the roboRIO.
