Go to Post Gracious professionalism dictates that if you come to play, I must help you. - Al Skierkiewicz [more]
Unread 15-01-2015, 17:54
aweso_meme aweso_meme is offline
FRC #4687
aweso_meme is an unknown quantity at this point
Lifecam HD3000 setup
Hello all,
I can't seem to set up the Microsoft Lifecam 3000 camera. I want it to display video without image processing to a dashboard (any dashboard works). I have looked in the RoboRio web interface, and the name of the camera is "cam0". I then booted up the java tutorial "SimpleVision" and ran it. No image appeared on the dashboard (SmartDashboard didn't recognise a camera, The FRC Default and Java dashboards didn't show anything even after I pressed play and cycled through all of the cameras). I literally have taken the Lifecam 3000 out of the box and plugged it in to the RoboRio. Does anyone have any Idea what is happening? If at all possible, I would like the display to be sent out to the Default FRC Dashboard, however any dashboard is acceptable.
Thank you all in advance.
