Go to Post According to a 6 year old I once met at a demo, our FRC machine was not a robot because, "How can it be a robot if it doesn't have a face?" - Jared Russell [more]
Unread 01-15-2015, 07:46 PM
BLUEBELL BLUEBELL is offline
FRC #3773
BLUEBELL is an unknown quantity at this point
Exclamation Using Netbeans
Hello everyone greetings from team 3773. Is there a way to use Netbeans instead of Eclipse for programming FRC robot in Java? My team has a very old computer and must use a platform independent development environment, and Eclipse does not work as well as Netbeans does in this respect. If anyone has any information about using Netbeans instead of Eclipse for the 2015 FRC Java programming please let me know.
Unread 01-15-2015, 08:12 PM
AlexBrinister AlexBrinister is offline
AKA: Alex Brinister
FRC #1768 (RoboChiefs)
Rookie Year: 2012
AlexBrinister will become famous soon enough
Re: Using Netbeans
Why does Eclipse not work as well? It is also platform independent.
You would need to do all of the configuration manually. For example, you would need to reference the wpilib and networktables jars in your project manually. You would need to write commands/commandgroups manually instead of using a context menu to make a new one. That's not a huge deal. The debugger and deploy function would need to be set up manually. In other words, yes, you can do it but its a pain.
Alex Brinister
Unread 01-15-2015, 09:36 PM
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Rookie Year: 2010
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
Re: Using Netbeans
"must use a platform independent development environment"
Do you understand what platform independent means? Eclipse lags the PC as much as Netbeans does - we also use an old computer but Eclipse works just fine. The amount of work required to use Netbeans is not worth the reward in my opinion.
Unread 01-16-2015, 12:55 PM
mspoehr mspoehr is offline
AKA: Michael Spoehr
FRC #2771 (Code Red Robotics)
Rookie Year: 2013
mspoehr is an unknown quantity at this point
Re: Using Netbeans
I am currently working on this. I don't like Eclipse, only because I don't think it is as polished as NetBeans is. In theory, as long as you have the libraries and the necessary build scripts, you should be able to use any IDE. I am working on simply using Ant to build and deploy. I have it working to the point that it compiles and deploys code the roboRIO, but for some reason the rio doesn't like something about the code. I'll get back to you if I figure it out.
Unread 01-16-2015, 01:31 PM
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
Rookie Year: 2010
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
You should just be able to use the existing ant scripts in ~/wpilib/java/current/ant/. The relevant files are the build.xml, build.properties, and the robotCommand/robotDebugCommand scripts.
