Thread Tools |
Rating:
Display Modes |
Re: New Vex Mecanum
The OP might have been asking for real world testing. After the issues with VEX's last iteration, I would consider that prudent.
Re: New Vex Mecanum
Wouldn't real world testing be competition? So the next best thing would be the kind of testing that Aren did.
Re: New Vex Mecanum
Unless you email VexPro, you probably won't know how the wheels were tested. For all we know they could have tested the wheels with a 50 pound robot, which is unlikely but without data we don't know. |
Re: New Vex Mecanum
We bought a set of the new rollers and installed them on last year's machine. We've been running it around the shop as vigorously as possible for the last two days. We have experienced zero breakage and only normal signs of wear.
We have decided that Vex solved their issues from last year and we have confidence in the new design. |
Re: New Vex Mecanum
Re: New Vex Mecanum
Correct. We can still tell a difference though. The signs of looseness and fatigue showed up early last year. They didn't start breaking until after extended use. We aren't seeing the looseness occur yet. I'll post an update after another week or so.
Re: New Vex Mecanum
We have a set as well, and will hopefully be running them Saturday. We'll post any info as we go along.
Re: New Vex Mecanum
All, the testing we completed with the 6" mecanums was fairly simple, four wheels, properly oriented, test bed weighed up to 150lbs (max robot with batteries and bumpers), and then handed to a High school intern who has no regard for the safety and well being of the wheels.
He was then told "break these" and came back after several hours of driving with the rubber worn off the rollers, no broken tabs. I later found out his testing included driving around on sidewalks and over significant bumps and door jams, in addition to running around on FRC carpet. Note, we are also working on specific testing on the current field with additional weight for the game pieces, we expect positive results given the previous testing described above. Hope this answers your questions, -Aren |
Re: New Vex Mecanum
Re: New Vex Mecanum
Re: New Vex Mecanum
-Aren |
#12
Re: New Vex Mecanum
FYI Aren Hill IS Vex, he is one of the engineers there. I'm sure he'll provide more data on their testing if you ask.
#13
Re: New Vex Mecanum
He has now provided the details that were missing. Quote:
#14
Re: New Vex Mecanum
Re: New Vex Mecanum
AndyMark did a great job documenting their tests on their Mecanum wheels, while haven't seen any quantifiable data on the VEX wheels. I'm curious how the VEX wheels would hold up if they were put through the same tests as the AndyMark wheels. |
