Thread Tools |
Rating:
Display Modes |
Re: Autonomous Strategy
The container set does not need to be the ones by the totes. It would be more beneficial for them to off the step.
The Q&A really fleshed out the auton ability shout out to that.
I am sad you can't make more then one container set though. |
Not during the regular season but once during an off-season event.
Maybe as an offseason parlor trick. Still betting against it.
Think about how rare it was in 2012 to have 2 robots feed their pre-loads into the 3rd who shot all 6. That happened an extremely low number of times. Thiw would be much more difficult to coordinate than that was. I hope teams with only so much resources (everyone is limited on time) do not invest a lot on creating multiple routines to specifically tailor to this. I have a feeling your effort may go to waste. |
Would you be willing to bet an alliance worth of Pronto Pups?
I find the idea extraordinarily attractive, but to be realistic, would probably not work out.
The fact of the matter is this: Each team should at least be able to put one yellow tote into the zone, and thus collectively gain points for the alliance. However, it would not be a bad idea to at least program your robot to find a second yellow tote, and stack on top of that one. This way, even if the third member doesn't quite fit the bill, you still should have a stack of at least 2. |
You get points for a set of 3 yellow totes in the AUTOZONE and more points if the set is stacked. There are zero points for a stack of 2 if the third tote is not also in the AUTOZONE. The yellow totes have no value (stacked or otherwise) in teleop unless you then move them to the STEP.
