Go to Post The more women we have as 'rock stars' in FIRST, the more girls we'll see celebrating math and science and the doors they can open. - JaneYoung [more]
Unread 16-01-2015, 13:33
team-4480's Avatar
team-4480 team-4480 is offline
Debug? What's that?
FRC #4480
Rookie Year: 2013
team-4480 will become famous soon enoughteam-4480 will become famous soon enough
RobotPy D eploy Error? What are we missing?
Hi! We ran into a code deploy problem we are not sure how to fix them(first year using python). I linked the error message below. I entered in the command "py robotcode.py deploy" which brought the error message. I have robotpy installed on the roboRIO. Any help will be greatly appreciated.
Unread 16-01-2015, 14:04
Peter Johnson Peter Johnson is offline
WPILib Developer
FRC #0294 (Beach Cities Robotics)
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
Re: RobotPy D eploy Error? What are we missing?
You should put your robot code into its own directory. It looks like the directory where your robotcode.py is has other files in it (e.g. a pyfrc directory), so it's getting confused between the installed pyfrc (in C:\Python34) and the one in the local directory.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 16-01-2015, 14:24
team-4480's Avatar
Debug? What's that?
FRC #4480
Rookie Year: 2013
Ok so I got a new problem when trying to upload. With your help I was able to get farther. See image for details.
Unread 16-01-2015, 14:38
WPILib Developer
That looks like a successful upload (the last message is just saying there wasn't previous robot code running). Note you should be uploading as "lvuser" rather than admin. If the robot code still isn't running, either check netconsole or use putty to log in as lvuser, run "sh robotCommand" (if the first time prints out an error like "socket in use" or "FRC pid XXX did not die within 110 ms, aborting", wait a few seconds and try again), and see if that prints out any errors.
Unread 16-01-2015, 14:52
team-4480's Avatar
Debug? What's that?
FRC #4480
Rookie Year: 2013
Thanks for the responses and I am very happy to see the actual developer of robotpy here. I got a new error when I did what you said. See picture again.
Unread 16-01-2015, 15:02
WPILib Developer
Is your robot script named robot.py? Are there any files in the py directory? I'm not the author of the pyfrc parts, virtuald is (he frequents Chief Delphi as well), but it looks like pyfrc's deploy feature may always make robotCommand call robot.py, rather than using the actual name of the script used when deploying. As a workaround, try renaming your script to robot.py if it isn't already.
If there are no files in the py directory, it could also be permissions related since you were uploading as admin previously--if that's the case, try logging in as admin, removing /home/lvuser/py, and then retrying your upload as lvuser.
Unread 16-01-2015, 15:21
team-4480's Avatar
Debug? What's that?
FRC #4480
Rookie Year: 2013
Ok so I deleted the directory and I tried to upload the code again(see pic). I think the problem is that the command line saved my username and password for admin. How do I make it so I log in as lvuser after it already saved the info in cache? Thanks again!
Unread 16-01-2015, 15:41
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #1418 (), FRC #1973, FRC #4796, FRC #6367 ()
virtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant future
Remove .deploy_cfg and it will ask again (or just edit it). Also, upgrade to pyfrc 2015.1.0, as it no longer asks you for a username, and has other fixes.
Code:
c:\python34\scripts\pip.exe install -U pyfrc
Maintainer of RobotPy - Python for FRC
Creator of pyfrc (Robot Simulator + utilities for Python) and pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript)
2017 Season: Teams #1973, #4796, #6369
Team #1418 (remote mentor): Newton Quarterfinalists, 2016 Chesapeake District Champion, 2x Innovation in Control award, 2x district event winner
Team #1418: 2015 DC Regional Innovation In Control Award, #2 seed; 2014 VA Industrial Design Award; 2014 Finalists in DC & VA
Team #2423: 2012 & 2013 Boston Regional Innovation in Control Award
Resources: FIRSTWiki (relaunched!) | My Software Stuff
Unread 16-01-2015, 15:56
team-4480's Avatar
Debug? What's that?
FRC #4480
Rookie Year: 2013
Code:
Ok so I installed the latest Pyfrc and now, for some odd reason, I get a permission denied error. See picture for details. Thanks again for all the help!!
Unread 16-01-2015, 16:00
WPILib Developer
Use putty to log in as admin, then run "rm /home/lvuser/robotCommand". You may also need to do "rm -r /home/lvuser/py".
Unread 16-01-2015, 16:36
team-4480's Avatar
Debug? What's that?
FRC #4480
Rookie Year: 2013
I am super happy and thankful to say that the deploy worked! It showed up in the FRC driver station and everything! Thank you both so much for taking the time to help us with robotpy and pyfrc!!
Unread 16-01-2015, 17:14
virtuald's Avatar
RobotPy Guy
Great to hear. Sorry about the problems... I expect that you shouldn't run into any more deploy issues now that you're using the newest version of pyfrc.
