Go to Post *POP!* I suppose I'll have to change my hair style to the John V-Neun now. - Billfred [more]
Unread 16-01-2015, 16:15
TACOCAT's Avatar
TACOCAT TACOCAT is offline
FRC #4935 (T-Rex)
Rookie Year: 2014
TACOCAT is an unknown quantity at this point
Question Gyro Help
Recently, we have tried to program our gyro but LabVIEW seems to find an error that is setting us back. We want to know if we could get some help with this since this is a real headache pls. GyroOpen seems to be the problem but everything is wired up correctly.
We are using this guide for gyro - https://decibel.ni.com/content/docs/DOC-26313
Unread 16-01-2015, 16:49
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Gyro Help
Originally Posted by TACOCAT View Post
...LabVIEW seems to find an error...
We can't see that error unless you show it to us. If we don't know what it says, we're not likely to be able to help you resolve it.
...everything is wired up correctly.
Prove it. :-) Tell us what kind of gyro you are using, and describe exactly where you are connecting each of its pins. If possible, take a picture and post it so we can see what you are talking about.
Unread 17-01-2015, 11:34
TACOCAT's Avatar
FRC #4935 (T-Rex)
Rookie Year: 2014
Re: Gyro Help
Sorry about that, here are the photos of the problem
Just for Reference - This is the part number of the gyro we are going to use (ADW22307)
ID:	17878  Click image for larger version
Unread 17-01-2015, 16:32
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Re: Gyro Help
That appears to be a cRIO project, because it says 'slot 1' rather than 'controller 1'.
Are you doing this on a roborio? If so, you started the wrong framework when creating the project.
Unread 18-01-2015, 10:41
arizonafoxx's Avatar
arizonafoxx arizonafoxx is offline
FRC #4395 (T-Rex)
arizonafoxx is an unknown quantity at this point
Re: Gyro Help
Greetings,
Let me clarify what one of our students is trying to explain so everyone has more detail on what we are seeing.The project is setup as a RoboRio project. So far this is the only WPI library we can not get to work. The Gyro Open.vi appears to not be upgraded for some reason. Our motors, joystick, encoders, digital I/O, Solenoids all compiled correctly. Motors and joystick hardware have been tested on the RoboRio with this code minus the Gyro Open.vi As of right now it is not a Gyro hardware issue because the code will not compile with the Gyro Open.vi present in the code.
We are wondering if any other teams are having the same issue?
Unread 18-01-2015, 11:28
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Gyro Help
I'd suggest trying the stand-alone gyro example found from the Getting Started window under:
Support -> Find FRC Examples... -> FRC Robotics -> roboRIO -> Sensors -> Gyro
That eliminates any code on your part as the cause and gives a wiring diagram to double-check.
I promise that the example works fine for me.
Note: the examples are setup to run over the USB connection by default.
I should reinforce what Tom mentioned. It appears that code has an old Gyro vi from last year, as if someone cut and pasted it from old code rather than building it from the 2015 palette.
Unread 22-01-2015, 21:20
controls weenie's Avatar
controls weenie controls weenie is offline
FRC #2973
Rookie Year: 2011
controls weenie is an unknown quantity at this point
Re: Gyro Help
I also found an anomoly using the LabVIEW vi. The analog gyro open command works fine on ai0 and ai1 but there are no selection inputs for ai2 and 3. Also there is only one controller selectable which does not include the mxp connector. Looks like we need another software upgrade soon from ni.
Unread 23-01-2015, 06:28
Greg McKaskle Greg McKaskle is online now
Re: Gyro Help
Or since the code consistently indicates that you can only choose channel 0 or channel 1, perhaps that is a limitation of the fpga accumulator.
Do you need this for the other channel, or were you just noticing it?
Greg McKaskle
Unread 23-01-2015, 07:07
FRC #2973
Rookie Year: 2011
Re: Gyro Help
Greg, there are 4 ain connectors on the front roborio and 4 on the mxp. Surely, ni programmed the FPGA to handle all 8 AIN lines or NI would have said something. I would like to use more than 2 AIN lines.
Thanks,
Unread 23-01-2015, 08:29
Re: Gyro Help
There are eight AI, but how many accumulators are there? And are they multiplexed to allow for any AI to feed into them?
I believe the raw AI and other analog items like pots let you use the four built-in and four MXP channels.
I couldn't find definitive documentation, so I'm interpreting someone's code for intent. I can verify a bit later today, and if I'm wrong, I'll file the bug report and let you know how to work around the bug in the wrapper. But from what I see, it looks like the wrapper is guiding you to pick from the only channels that make sense due to the underlying implementation.
Greg McKaskle
Unread 23-01-2015, 09:48
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Rookie Year: 2010
adciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to all
Re: Gyro Help
In the cRIO system, you could only use gyros on AI1 & 2 (0 & 1 on the RoboRIO). This limitation is not new.
Originally Posted by texarkana View Post
I would not want the task of devising a system that 50,000 very smart people try to outwit.
