Go to Post yesterday we completed our bot mechanically and let me tell you.... i was jumping up and down like a 12 year old girl going to a boy-band concert - Leav [more]
Unread 16-01-2015, 20:10
gaut1234 gaut1234 is offline
AKA: Gautam Prabhu
FRC #0972 (Iron Claw)
Team Role: Leadership
Rookie Year: 2014
gaut1234 is an unknown quantity at this point
IndexOutOfBoundsException with NI Vision
We have been using an axis M1013 IP camera for our vision system this year. We slightly modified the Axis Camera example program to save pictures the camera takes to the roboRIO for debugging purposes. We have repeatedly gotten "IndexOutOfBoundsException" with our call to the HSLImage class's "write" function. We have tried a lot of debugging and I think that the problem lies with ByteBuffer allocation in the roboRIO (this happens internally in WPILIB's writing function) but we have not fully confirmed this. In addition, the example axis program does not work as expected - we get no image on the dashboard. We can view the camera from the SmartDashboard and we can use the getImage() function without exceptions.
Thank you for your help.
Unread 17-01-2015, 00:26
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
Rookie Year: 2010
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
We should have a new wpilib release out within the next day or two that will hopefully fix the problem, please let us know if that doesn't fix it.
Unread 17-01-2015, 17:29
AKA: Gautam Prabhu
Rookie Year: 2014
Re: IndexOutOfBoundsException with NI Vision
Thank you! We used the 01-16-15 version and it worked.
