Go to Post As a rookie team member at my first event, i had a great time, the little glitches meaning nothing. - Gluedtothefloor [more]
Unread 16-01-2015, 23:52
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
Rookie Year: 2013
xXhunter47Xx will become famous soon enough
USB B cable stuck in RoboRIO
Help. It's stuck and we kind of want to take it out.
College sux yo
Unread 17-01-2015, 00:14
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: USB B cable stuck in RoboRIO
What did you do to get it stuck? What have you tried to fix the problem?
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 17-01-2015, 02:24
Lord of Lazy
Rookie Year: 2013
I don't know how else to explain it. We plugged it in to flash the firmware and now we want to take it out but it's stuck in there. We've tried pulling it straight out but that didn't work. There's not much else to do that I can think of.
College sux yo
Unread 17-01-2015, 06:14
J. Tumavitch J. Tumavitch is offline
FRC #2832
J. Tumavitch is an unknown quantity at this point
We had the same problem during beta testing. Some clips that are supposed to provide some holding force on the connector are bent out too far.
To fix it we pushed stiff plastic from some discarded packaging in between the connector and the socket on all four sides and then wiggled it back and forth until it came free.
Unread 17-01-2015, 13:16
Lord of Lazy
Rookie Year: 2013
Great, glad I'm not the only one with this issue.
I think we're just gonna keep it bundled up and tucked away instead of shoving plastic in the sides every time we want to disconnect.
College sux yo
Unread 17-01-2015, 14:23
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Please try to correct the problem so the cable can be removed when you're not using it. If a "tucked away" cable comes loose and the metal shell of the USB connector contacts something electrified, you have a real chance of frying the roboRIO.
Unread 17-01-2015, 15:26
Lord of Lazy
Rookie Year: 2013
We will correct it when it's on the actual bot with moving parts, right now it's just on a test board to test code while build team builds a prototype chassis.
College sux yo
Unread 17-01-2015, 15:36
Amar Shah Amar Shah is offline
FRC #1899 (Saints Robotics)
Team Role: CAD
Rookie Year: 2012
Amar Shah has a spectacular aura aboutAmar Shah has a spectacular aura aboutAmar Shah has a spectacular aura about
A USB pigtail would be a good solution to this problem.
Unread 24-01-2015, 23:33
4CSND 4CSND is offline
FRC #5070
4CSND is an unknown quantity at this point
Yes this has also happen to use. We rolled the cord up and placed electrical tape over the end. Cannot afford another one. Too afraid to try and pull it out. Thank for letting us know that we were not crazy.
Unread 07-02-2015, 18:22
FRC #5070
We have not had any luck with removing the usb cord from the RoboRio. Any other suggestions?
