Go to Post The gearbox can be anything, just as long as it weighs less than 0 lbs, and yes, I'm talking about negative weight here. - NoodleKnight [more]
Unread 17-01-2015, 00:16
mandrews281 mandrews281 is offline
FRC #0281
mandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to behold
Bug Reporting??
Does anyone know where we should go to report bugs in the library and/or the documentation?
The online documentation describes a CanTalonSRX, yet this class does not exist in the WPILib _EXCEPT_ in the WPILib.h file. Use CANTalon instead.
Michael Andrews
Team #281 Programming Mentor
Unread 17-01-2015, 00:32
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond repute
Re: Bug Reporting??
Where exactly?
http://wpilib.screenstepslive.com/s/...ommit=Se arch
The bottom of each article has a forum to post suggestions/errors.
CanTalonSRX is used by CANTalon. CANTalon is meant to be used by teams as it implements some additional class interfaces.
Unread 18-01-2015, 17:58
FRC #0281
Re: Bug Reporting??
Yes. The screensteps does have space for suggestions; but the WPI C++ documentation site doesn't. I would suggest they mention in the doc for CanTalonSRX that it is an internal class and teams should use CANTalon.
It's no big deal now, but it is confusing.
Michael Andrews
Unread 18-01-2015, 18:22
ozrien's Avatar
Omar Zrien
AKA: Omar
Re: Bug Reporting??
For Talon SRX specifically check out the Software Reference Manual...
http://www.crosstheroadelectronics.c...ol_system.html
...bottom of the page. Also has docs for the other control system components.
For everything else I usually defer to FRC screensteps.
