Go to Post "Field orientation is like a homing pidgeon that can fly backwards." - LostWolf [more]
Unread 01-17-2015, 09:00 AM
Jaci's Avatar
Jaci Jaci is online now
AKA: Jaci R Brunning
FRC #5333 (Can't C# | OpenRIO)
Rookie Year: 2015
Jaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond repute
GradleRIO - Developing for RoboRIO without Eclipse
Personally I'm not a big fan of eclipse, I much prefer IntelliJ IDEA for various reasons.
In the recent few days I've decided to make a gradle plugin that allows for fetching of WPILib resources, setting up of workspace/project and deploying code to the RoboRIO without the need for eclipse, only a command line and any IDE you like.
Here's the link to the project: https://github.com/Open-RIO/GradleRIO
If you end up using it, let me know if you find any bugs
~Jaci
Unread 01-17-2015, 10:17 AM
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Rookie Year: 2012
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Re: GradleRIO - Developing for RoboRIO without Eclipse
Oh my god! It's about time somebody makes it a gradle pluggin! Nice work! Im a huge fan of gradle! If my favorite ide (currently eclipse) changes between this season and next season I will actually use this.
Unread 01-26-2015, 02:26 PM
felix156 felix156 is offline
FRC #5759
felix156 is an unknown quantity at this point
Hello,
Thanks for making the gradle plugin!
When I do "gradlew deploy" it doesn't deploy.
I'm connected to the robot's network, and have specified the team number and everything in the build.gradle file. It still throws a FileNotFoundException - says the file GradleRIO.jar cannot be found. I specified it as a library in Intellij, however.
Any ideas why this might be the case?
Regards,
Felix
Unread 01-26-2015, 07:48 PM
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
You could also use vanilla gradle without a plugin to deploy. I've been using this script for a while in IntelliJ.
https://gist.github.com/ThomasJClark...c24c395aa2e9b4
Unread 01-28-2015, 08:36 PM
Jaci's Avatar
Rookie Year: 2015
Originally Posted by felix156 View Post
Hello,
Regards,
Felix
Try running gradlew build before deploying. If you're on UNIX (Mac/Linux) chmod the entire directory as 777
Unread 10-18-2015, 01:22 PM
smarthimandrew's Avatar
smarthimandrew smarthimandrew is offline
Programmer, and (sigh) Electrical
AKA: Andrew Dickinson
FRC #3546 (Buc 'n' Gears)
Rookie Year: 2013
smarthimandrew is an unknown quantity at this point
Did you create the Linux gradlew script on a windows box? The newline characters seem to break bash. You need to run "dos2unix gradlew" before anything will work.
Unread 10-19-2015, 05:53 PM
wazateer1 wazateer1 is offline
FRC #3506 (YETI Robotics)
Rookie Year: 2013
wazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to behold
Thanks for the awsome project, this might fix my issues with eclipse luna!
When you make a new release on github, please remember to change your build.gradle. It causes issues when you go straight to a new release.
[EDIT] I saw the commit on github where someone changed it, but for some reason this was not reflected in the latest release .zip Maybe you need to re-build it? (I am not familiar with githubs release system)
