Go to Post We can still do better, even if we've come a long way. - cadandcookies [more]
Unread 01-17-2015, 01:11 PM
nathanv's Avatar
nathanv nathanv is offline
nathanv
AKA: Nathan Vaniman
FRC #4984 (Bullseye)
Rookie Year: 2013
nathanv is an unknown quantity at this point
No consyole feedback when deploying with eclipse
Whenever I try to deploy code to the ROBOrio with eclipse, I do not get anything in the console window. Also, when I build, I get the errors "Program GCC not found in PATH" and "Program G++ not found in PATH." I was told that these errors should be ignored and are not the problem. The code will not deploy. I tried uninstalling the toolchain and the NI update, and neither of these work. Has anyone else had this issue?
Thanks!
Unread 01-17-2015, 01:17 PM
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Re: No consyole feedback when deploying with eclipse
So you click WPILib Deploy in the menu and you see nothing at all in the Eclipse Console?
Unread 01-17-2015, 01:18 PM
nathanv's Avatar
nathanv
AKA: Nathan Vaniman
Rookie Year: 2013
that is correct.
Unread 01-17-2015, 07:35 PM
jfitz0807 jfitz0807 is offline
FRC #2877 (Ligerbots)
Team Role: Parent
jfitz0807 is an unknown quantity at this point
Check your Riolog window. Go to Window->Show View->other...
In the resulting "Show Window" pop-up, selec "General" then "Riolog" and click "OK". The Riolog window will show up as a tab next to the Console.
Build results still go to the console, but printf et al go to the Riolog window.
Unread 01-19-2015, 11:27 AM
RushAHead RushAHead is offline
FRC #3103 (Iron Plaid)
Rookie Year: 2014
RushAHead is an unknown quantity at this point
I do not believe "Program GCC not found in PATH" and "Program G++ not found in PATH." are safe to ignore. They indicate the toolchain is not being found and without that your program is not being compiled. Try adding the path to the toolchain to your System PATH environment variable. Should be something like:
C:\frc\bin;
I believe this is mentioned on the ScreenStep C++ installation page somewhere.
Unread 01-19-2015, 01:58 PM
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
C:\frc\bin;
Toolchain maintainer here: they are safe to ignore. Now if those said "arm-frc-linux-gnueabi-g++ not found in PATH" then you have an issue. We don't create or install binaries with the strict name "g++" as that is reserved for the current system compiler and we don't want to mess with people who have the MinGW toolchain installed for local development. If the toolchain installer does not add that to the system path, then that is a bug in the installer and please let me know.
Those errors about "gcc" and "g++" are from the base eclipse package trying to get default values for new system projects and will only cause issues if you want to develop for your local machine instead of the RoboRIO.
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 01-19-2015, 03:11 PM
Rookie Year: 2014
I stand corrected. We ran across the same errors (I think it was just the 2 errors, I don't recall the 'arm-frc...' error) on one of our installs (Win7, 64 bit, non-admin user account) and found the path to be missing. When the path to the toolchain was added the errors went away. We assumed that was the cause, though it is possible something else was changed as well.
