Go to Post If you never takes steps to solve problems you cannot just complain that they exist. - Wayne C. [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 17-01-2015, 14:39
FYRE5480 FYRE5480 is offline
FRC #5480
FYRE5480 is an unknown quantity at this point
Allowed Computers and Internet Access
Does anyone know if we are allowed to use a computer other than the mini we got in the kit of parts to drive?
Also, we have that computer, but it does not have wireless internet capabilities. It has to be plugged into Ethernet to get any connections. We have already tried resetting the drivers and nothing happened. Does anyone know what we can do to try and fix this?
Unread 17-01-2015, 16:03
afera's Avatar
afera afera is offline
FTA - FIRST in Michigan
AKA: Alexander Fera
FRC #0503 (Frog Force)
Rookie Year: 2007
afera is a splendid one to beholdafera is a splendid one to beholdafera is a splendid one to beholdafera is a splendid one to beholdafera is a splendid one to beholdafera is a splendid one to behold
Re: Allowed Computers and Internet Access
You can install the FRC Driver Station on any Windows computer or Windows VM (I do not recommend the VM) for use at competition. As for wireless this is not needed at events and recommended to be disabled, you just need to use the Ethernet port to connect to the FMS. The field creates the wireless network for you.
The directions to install the DS are found here: https://wpilib.screenstepslive.com/s...anual-id=13503
Alexander Fera
FIRST Technical Advisor (FTA) and Control System Advisor (CSA) - FIRST Robotics Competition
Lead FIRST Technical Advisor (FTA) and Assistant Affiliate Partner - FIRST Tech Challenge
FIRST in Michigan, Facebook and Twitter
2017 FRC: Lakeview, St. Joseph (IN), Gaylord, Woodhaven, Livonia, MSC and CMP - St. Louis
2016-2017 FTC: Big Rapids, Pestokey, Marysville, Coloma, Concord, MSC, North Super Regional and CMP - Houston
Volunteer Since 2009 and Alumni/Mentor of 503 Frog Force ('11)
FRC FTA since '14 and CSA since '12 | FTC FTA and CSA since '11
LinkedIn
Unread 18-01-2015, 17:39
FRC #5480
I was just wondering about the wireless capabilities when we are practice driving. If we cannot connect to the robot then, we cannot practice drive. Thank you for letting us know about the other allowed computers though.
Unread 18-01-2015, 18:21
TFleig78's Avatar
TFleig78 TFleig78 is offline
AKA: Tyler
FRC #0078 (Air Strike)
Rookie Year: 2012
TFleig78 will become famous soon enoughTFleig78 will become famous soon enough
You can use any computer you want to practice driving. It just needs to be able to run the 2015 driver station. It is recommended to have a computer with wireless capabilities, but if not, you can drive while tethered(using a long ethernet cable).
Same for the competition. As long as you have wired network capability, you can use that computer for competitions. You do not need WiFi for competitions, and it is disallowed in the competition building.
