Go to Post DEKA is right next to the river, and when i got there this morning they wouldn't let us into the building, but apparently there is and standing water on the first floor. The ironic thing is that i work on the water project and we can't deal with a bit of water on the floor - Greg Needel [more]
Unread 17-01-2015, 15:04
FRC3941N FRC3941N is offline
FRC #3941
FRC3941N is an unknown quantity at this point
Wireless Driver Station Practice
We have been trying all day to wirelessly connect our computer to our roboRIO. We tried using the National Instruments Bridge Configuration software but we got an error saying that the bridge couldn't be configured because the IP address configuration failed. We messed with the settings on the d-link and the NIBC software to see if that was the problem but we still got the same error. We changed the computer's IP address to match the d-link's address and then tried again and still got the same error. We then set it so the computer would automatically receive an IP address and then opened the driver station software and the driver station said that there was communication, but we couldn't do anything with the robot. We then tried to ping the roboRIO IP address and got nothing back, so the d-link and the roboRIO aren't communicating for some reason. Does anybody know how to get the d-link and roboRIO to wirelessly communicate and/or the cause of the "IP address configuration failed" error?
Unread 17-01-2015, 15:52
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Wireless Driver Station Practice
I'm pretty sure the failure is telling you that the configuration tool is unable to change the IP address on your computer. Try running it as administrator. And it's usually a good idea to disable all of the network adapters except the single wired interface that you're using to connect to the D-Link.
Unread 17-01-2015, 17:06
team-4480's Avatar
team-4480 team-4480 is offline
Debug? What's that?
FRC #4480
Rookie Year: 2013
team-4480 will become famous soon enoughteam-4480 will become famous soon enough
Try resetting the router or image the RIO again. You have the Ethernet plugged in, right? We ran into the exact same issue and by resetting the router, we didn't get the error anymore. Best of luck!
Unread 17-01-2015, 23:54
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
Rookie Year: 2013
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
I tried configuring the radio today, and while it successfully configured on the first try, it doesn't seem to work.
I open up the driver station and connect to the radio, but I can't get communications. Similarly, I can't open up roboRIO-2067.local/ in a browser.
With the old control system, I would know how to troubleshoot connection issues, but now I have no idea what I'm doing.
Head Programmer / Driver
Unread 18-01-2015, 07:18
The diagnostics are pretty similar.
What do the DS Diagnostics LEDs look like? What does ipconfig tell you? How is the switch and LEDs on the DLink setup?
The DLINK DHCP server will distribute 10.te.am.20+ IP addresses. If you have one of those, it is probably working, otherwise not.
And of course there are pesky firewall issues that are just as hard to diagnose as always.
Greg McKaskle
