Go to Post Don't Canadians spell it that way? Someone should cheque on that.... - Travis Hoffman [more]
Thread Tools Rating: Thread Rating: 9 votes, 4.89 average. Display Modes
Unread 17-01-2015, 16:14
el_pablo el_pablo is offline
AKA: Nicolas Bourré
FRC #4007
Rookie Year: 2012
el_pablo is an unknown quantity at this point
Remote command failed with exit status 1
Hi,
We are trying to program our roboRio for the first time. We are unable to send code and we are getting this error "Remote command failed with exit status 1". I googled and haven't found a solution for this error.
Can someone help with this?
Thanks!
Nicolas Bourre
Team 4007
Seminaire Ste-Marie
Unread 17-01-2015, 16:27
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Remote command failed with exit status 1
The real error is probably somewhere above what you posted. Please post the entire log.
Unread 17-01-2015, 17:26
1024Programming 1024Programming is offline
FRC #1024
1024Programming is an unknown quantity at this point
We had the same problem, the way we found to fix it is to load the code as admin instead of lvuser. if you click the [sshexec] it will open the build.xml. In the build.xml, replace all "${username}" with "admin" and all "${password}" with "". I don't know if that's the solution FIRST wants us to use, but it lets us load code onto the robot. If someone else has a better fix I'd very gladly try it.
Unread 22-01-2015, 10:25
Dinnesy Dinnesy is offline
FRC #4968 (Robo Hawks)
Team Role: Teacher
Rookie Year: 2014
Dinnesy is an unknown quantity at this point
I tried changing the username to admin and leaving the password blank, however after i change them, I get the following error:
BUILD FAILED
C:\Users\Ryley Ongarato\wpilib\java\current\ant\build.xml:106: com.jcraft.jsch.JSchException: SSH_MSG_DISCONNECT: 2 Too many authentication failures for ${admin}
Am I doing something wrong? I tried using find and replace to replace all of them. I also tried only changing one of them.
Thanks.
Unread 24-01-2015, 10:54
pluto7443 pluto7443 is offline
FRC #4917
pluto7443 is an unknown quantity at this point
Exclamation Re: Remote command failed with exit status 1
Hey - us at 4917 had this exact error. There were 3-10 of us working on it for about 6 hours before we figured it out. All solutions in this thread did not work.
We had to re-image our roboRIO. In order to do that:
-Open NI LabVIEW 2014 (when it opens it should say "FRC 2015 Getting Started" at the top)
-Go to utilities
-Re-imaging tool roboRIO 2015
-Hooked up the roboRIO with a USB printer cord
-Re-image roboRIO. This failed 4 times for us before successfully completing.
-After successfully completing, you should be good to download!
Hope it helps!
Unread 24-01-2015, 23:30
lucas.alvarez96's Avatar
lucas.alvarez96 lucas.alvarez96 is offline
AKA: Lucas Alvarez
FRC #2576 (Chilean Heart)
Rookie Year: 2013
lucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to all
Ok, so we had the same problem today and this is what I've gotten so far:
  • We configured the admin user on the roboRIO interface with computer A
  • We flashed the roboRIO, installed the Java 8 VM and flashed the VRM and PCM with computer A
  • I then attempted to upload a new code we had been working on with multiple classes onto the roboRIO with computer B
  • The upload process failed due to the privileges error previously described on this thread
  • I modified C:\Users\[USER]\wpilib\java\current\ant\build.xml by replacing all "${username}" with the username previously selected during the config/flash process. I did the same with the "${password}" field
  • I succesfully uploaded a sample tank drive robot code provided in the examples and managed to get all 3 green lights (comm, code, input) on the DS
  • When trying to upload the previous code with multiple classes once more, I received the following error:
    Code:
    ERROR Unhandled exception instantiating robot com.team2576.Robot java.lang.ClassNotFoundException: com.team2576.Robot at [java.net.URLClassLoader$1.run(URLClassLoader.java:372), java.net.URLClassLoader$1.run(URLClassLoader.java:361), java.security.AccessController.doPrivileged(Native Method), java.net.URLClassLoader.findClass(URLClassLoader.java:360), java.lang.ClassLoader.loadClass(ClassLoader.java:424), sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:308), java.lang.ClassLoader.loadClass(ClassLoader.java:357), java.lang.Class.forName0(Native Method), java.lang.Class.forName(Class.java:259), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:197)]
  • I then re-uploaded the original example code and realized the build log included the following output with an error:
    Code:
    Buildfile: C:\Users\Lucas\FRC_Java\Tank Drive\build.xml
    Trying to override old definition of task classloader
    clean:
       [delete] Deleting directory C:\Users\Lucas\FRC_Java\Tank Drive\build
       [delete] Deleting directory C:\Users\Lucas\FRC_Java\Tank Drive\dist
    compile:
        [mkdir] Created dir: C:\Users\Lucas\FRC_Java\Tank Drive\build
         [echo] [athena-compile] Compiling src with classpath=C:\Users\Lucas/wpilib/java/current/lib/WPILib.jar:C:\Users\Lucas/wpilib/java/current/lib/NetworkTables.jar to build
        [javac] Compiling 1 source file to C:\Users\Lucas\FRC_Java\Tank Drive\build
    jar:
         [echo] [athena-jar] Making jar dist/FRCUserProgram.jar.
        [mkdir] Created dir: C:\Users\Lucas\FRC_Java\Tank Drive\dist
        [mkdir] Created dir: C:\Users\Lucas\FRC_Java\Tank Drive\build\jars
         [echo] [athena-jar] Copying jars from C:\Users\Lucas/wpilib/java/current/lib/WPILib.jar:C:\Users\Lucas/wpilib/java/current/lib/NetworkTables.jar to build/jars.
         [copy] Copying 2 files to C:\Users\Lucas\FRC_Java\Tank Drive\build\jars
          [jar] Building jar: C:\Users\Lucas\FRC_Java\Tank Drive\dist\FRCUserProgram.jar
    get-target-ip:
         [echo] Trying Target: roboRIO-2576.local
         [echo] roboRIO found via mDNS
    dependencies:
         [echo] roboRIO image version validated
         [echo] Checking for JRE. If this fails install the JRE using these instructions: https://wpilib.screenstepslive.com/s/4485/m/13503/l/288822-installing-java-8-on-the-roborio-using-the-frc-roborio-java-installer-java-only
      [sshexec] Connecting to roboRIO-2576.local:22
      [sshexec] cmd : test -d /usr/local/frc/JRE
    deploy:
         [echo] [athena-deploy] Copying code over.
          [scp] Connecting to roboRIO-2576.local:22
          [scp] done.
      [sshexec] cmd : killall netconsole-host
      [sshexec] killall: netconsole-host: no process killed
      [sshexec] Remote command failed with exit status 1
          [scp] done.
          [scp] done.
         [echo] [athena-deploy] Starting program.
      [sshexec] cmd : . /etc/profile.d/natinst-path.sh; /usr/local/frc/bin/frcKillRobot.sh -t -r;
      [sshexec] start-stop-daemon: warning: killing process 9451: No such process
    BUILD SUCCESSFUL
    Total time: 9 seconds
    Error:
    Code:
Any ideas on why the code doesn't deploy correctly for the multi class project?
FRC 2576 2015-???: Mentor
FRC 2576 2013-2015: Programmer & Chairman's Presenter
Los Angeles Regional 2013: Gracious Professionalism Award | Los Angeles Regional 2014: Regional Chairman's Award
Unread 16-02-2015, 12:44
Jtbillick Jtbillick is offline
FRC #4780
Jtbillick is an unknown quantity at this point
    Code:
    Code:
    clean:
    compile:
    jar:
    get-target-ip:
    dependencies:
    deploy:
          [scp] done.
          [scp] done.
          [scp] done.
    BUILD SUCCESSFUL
    Error:
    Code:
My team is having the exact same problem. I've been looking stuff up all night, but i still haven't found a solution
Unread 27-01-2015, 16:59
FRC #1024
BUILD FAILED
Thanks.
It shouldn't be ${admin} it should only be admin
Unread 14-02-2015, 12:57
BrighidKHeh's Avatar
BrighidKHeh BrighidKHeh is offline
FRC #3871 (Trojan Robotics)
Rookie Year: 2011
BrighidKHeh is an unknown quantity at this point
i'm from team 3871 we have tried all of these and it is still popping up with " remote command failed with status 1"
Unread 15-02-2015, 11:19
FRCteam5110's Avatar
FRCteam5110 FRCteam5110 is offline
Team Captain - Driver - Programmer
AKA: Caitlin Scroggins
FRC #5110 (Elks)
Rookie Year: 2014
FRCteam5110 is an unknown quantity at this point
Same issue here, I can still get the basic KitBot code to work so I'm getting the impression it's not a RoboRIO issue.
Unread 27-02-2015, 13:34
VEX_6333's Avatar
VEX_6333 VEX_6333 is offline
Captain, VEX Team 6333 CTRL_ALT_DEL
AKA: Thane McGarry
VRC #6333 (CTRL_ALT_DEL)
Team Role: Leadership
Rookie Year: 2014
VEX_6333 is an unknown quantity at this point
Hey all, we're new to ChiefDelphi as members, but your forums have saved us on multiple occasions. Long story short, we're getting the same error. It started as remote command failed with exit status 1 only appearing in the console (we're using Eclipse to write in Java) as an error, but the build succeeded, but wouldn't upload to the robot. We tried a hard cable link, same result. Then we tried re-imaging the RoboRio, and now the build fails with C:\Users\DOC\wpilib\java\current\ant\build.xml:239 : Remote command failed with exit status 1. Any help?
Thanks!
VRC Team 6333 CTRL_ALT_DEL
FRC Team 1765 E1Bots
Unread 02-03-2015, 14:37
legts legts is offline
Autonomous Queen
FRC #2399 (The Fighting Unicorns)
Rookie Year: 2012
legts is an unknown quantity at this point
My team has gotten the same error on some occasions. If I recall correctly what was wrong with our code was the robot package wasn't imported correctly. If I could see the imports of one of your commands I can check to see if my theory is correct.
Unread 02-03-2015, 19:51
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Rookie Year: 2012
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
There is usually an error some where else, try looking for the exception and posting it
Unread 03-03-2015, 10:26
VEX_6333's Avatar
AKA: Thane McGarry
Rookie Year: 2014
Has anyone actually solved this problem in a way that they can explain why what they did works? Everyone I've seen who has solved the issue seems to have fixed it by a fluke. Can someone explain exactly what the error even means? I can't even find a definition.
  #15   Spotlight this post!
Unread 03-03-2015, 11:26
Autonomous Queen
Rookie Year: 2012
The error is sort of encompasses a wide area of things. It can be Eclipse setup issues, package import stuff, and a whole host of other issues. I've seen it happen twice where packages aren't imported correctly and this error is thrown.
