Go to Post If everyone else in the world is an idiot, you may need to recalibrate your idiotness scale. - GaryVoshol [more]
Thread Tools Rating: Thread Rating: 9 votes, 4.89 average. Display Modes
Unread 03-03-2015, 12:24
VEX_6333's Avatar
VEX_6333 VEX_6333 is offline
Captain, VEX Team 6333 CTRL_ALT_DEL
AKA: Thane McGarry
VRC #6333 (CTRL_ALT_DEL)
Team Role: Leadership
Rookie Year: 2014
VEX_6333 is an unknown quantity at this point
Re: Remote command failed with exit status 1
So, you're saying that if we fix the package error, we'll be able to push code again?
Unread 03-03-2015, 12:36
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Do you have a package error? You haven't provided any information that would lead to that conclusion, he just posted one example. Because there are many things that could cause this message, including many in which there isn't any problem, you need to post the entire build log as well as the riolog for anyone to give you any advice.
Unread 03-03-2015, 13:00
VEX_6333's Avatar
AKA: Thane McGarry
Rookie Year: 2014
Okay, here is the build log:
Buildfile: C:\Users\DOC\workspace\DriveTrain\build.xml
Trying to override old definition of task classloader
clean:
[delete] Deleting directory C:\Users\DOC\workspace\DriveTrain\build
[delete] Deleting directory C:\Users\DOC\workspace\DriveTrain\dist
compile:
[mkdir] Created dir: C:\Users\DOC\workspace\DriveTrain\build
[echo] [athena-compile] Compiling src with classpath=C:\Users\DOC/wpilib/java/current/lib/WPILib.jar:C:\Users\DOC/wpilib/java/current/lib/NetworkTables.jar to build
[javac] Compiling 1 source file to C:\Users\DOC\workspace\DriveTrain\build
jar:
[echo] [athena-jar] Making jar dist/FRCUserProgram.jar.
[mkdir] Created dir: C:\Users\DOC\workspace\DriveTrain\dist
[mkdir] Created dir: C:\Users\DOC\workspace\DriveTrain\build\jars
[echo] [athena-jar] Copying jars from C:\Users\DOC/wpilib/java/current/lib/WPILib.jar:C:\Users\DOC/wpilib/java/current/lib/NetworkTables.jar to build/jars.
[copy] Copying 2 files to C:\Users\DOC\workspace\DriveTrain\build\jars
[jar] Building jar: C:\Users\DOC\workspace\DriveTrain\dist\FRCUserProg ram.jar
get-target-ip:
[echo] Trying Target: roboRIO-1765.local
[echo] roboRIO found via mDNS
dependencies:
[echo] roboRIO image version validated
[echo] Checking for JRE. If this fails install the JRE using these instructions: https://wpilib.screenstepslive.com/s...ller-java-only
[sshexec] Connecting to roboRIO-1765.local:22
[sshexec] cmd : test -d /usr/local/frc/JRE
deploy:
[echo] [athena-deploy] Copying code over.
[scp] Connecting to roboRIO-1765.local:22
[scp] done.
[sshexec] cmd : killall netconsole-host
[sshexec] killall: netconsole-host: no process killed
[sshexec] Remote command failed with exit status 1
[scp] done.
[scp] done.
[echo] [athena-deploy] Starting program.
[sshexec] cmd : . /etc/profile.d/natinst-path.sh; /usr/local/frc/bin/frcKillRobot.sh -t -r;
[sshexec] start-stop-daemon: warning: killing process 2831: No such process
BUILD SUCCESSFUL
Total time: 34 seconds
Does that help?
Unread 03-03-2015, 13:36
legts legts is offline
Autonomous Queen
FRC #2399 (The Fighting Unicorns)
Rookie Year: 2012
legts is an unknown quantity at this point
clean:
compile:
jar:
get-target-ip:
dependencies:
deploy:
[scp] done.
[scp] done.
[scp] done.
BUILD SUCCESSFUL
Does that help?
That looks like it should have worked. Can you post what the package you're working out of is? For my team it is "package org.usfirst.frc.team2399.robot;" inside of OI and Robot.java
Unread 03-03-2015, 13:43
VEX_6333's Avatar
AKA: Thane McGarry
Rookie Year: 2014
It's "org.usfirst.frc.team1765.robot" Does that help?
Unread 03-03-2015, 14:13
Rookie Year: 1997
Does that help?
Like legts said, this doesn't show a problem, just that no robot code was running. To find out why the robot code isn't running, please post your riolog, which will hopefully have a stack trace.
Unread 03-03-2015, 14:21
VEX_6333's Avatar
AKA: Thane McGarry
Rookie Year: 2014
I'm going to sound like a naive rookie, (which I kinda am) but how exactly do you do that?
