Go to Post I think it's important to keep FIRST's most important award as the top point getter [in Fantasy FIRST]. It's help reinforce that the Chairman's award, Engineering Inspiration and Woodie Flowers award are actually important and FIRST is about more than just the robots. - Koko Ed [more]
Unread 17-01-2015, 17:29
Intern Intern is offline
FRC #3596
Intern is an unknown quantity at this point
Cant get Axis camera feed on DS
i cannot get AXIS camera feed to our driver station, other teams have been having this problem too, out ip for the camera is 10.25.96.11, last year in labview i didnt have to do anything with the camera it was a plug and go, do i have to edit something.
Unread 17-01-2015, 17:50
Potatoes's Avatar
Potatoes Potatoes is offline
AKA: Eric Wittmann
FRC #5136 (Mecha Pirates)
Rookie Year: 2014
Potatoes is an unknown quantity at this point
Re: Cant get Axis camera feed on DS
Are you sure you have the ip correct? Since your team number is 3596, wouldn't the camera be on 10.35.96.11?
Unread 17-01-2015, 19:50
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
This year the default LabVIEW dashboard project used mDNS to address the camera and expects it to be at axis-camera.local
This year's Axis Camera Setup Utility gives it that address. - my mistake
If you want to use last year's address, then you just need to edit a default Dashboard project and replace the camera address with the static IP you want to use.
Unread 17-01-2015, 19:57
forbes's Avatar
forbes forbes is offline
Software developer
AKA: Evan Forbes
FRC #3507 (Ubotics)
Rookie Year: 2012
forbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to behold
My team used the setup utility, but the camera still had an address of "axis-[random looking numbers and letters].local", which I assume is the default.
Unread 17-01-2015, 19:59
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
The tool does not give it that address. The M1013 uses axis-camera.local by default. Older cameras need to be set in the advanced networking settings.
Unread 17-01-2015, 20:38
Yep. The Axis 1013 fooled me a bit. The older cameras include their serial number. The DS could truly use mDNS to locate a service, but instead, it appeared that we could just address with a device name. It really isn't that hard to set an M1011 or M206 to have that DNS name. I remember turning off auto, changing the name, and turning auto back on.
But of course you can use the DNS name that includes the serial number, or you can use a static IP. But make sure that the subnet lets it route to the dashboard and roboRIO.
Greg McKaskle
