Go to Post Introverts can be good leaders too, we just lead differently. - Ari423 [more]
Unread 17-01-2015, 19:31
MartianMechanic MartianMechanic is offline
FRC #5750
MartianMechanic is an unknown quantity at this point
Can't connect to D-Link
Hello Everyone.
Mi team is having trouble connecting with the D-Link via the Bridge Configuration Utility. When launching the application, the network interface pop-up appears without any options, even when connected via Ethernet cable.
Does anyone know what the problem might be?
We are a bit desperate; we haven't been able to connect to the robot. FYI we are newbies.
Thanks for the help.
Unread 18-01-2015, 16:06
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Can't connect to D-Link
You're using a Mexico-localized version of Windows, aren't you?
Some of the configuration tools get confused when the information they're trying to parse out of Windows doesn't match what they expect. If you have a US-English Windows system, try it instead. If you can't do that, there are manual configuration instructions around somewhere.
Unread 19-01-2015, 22:05
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Does it look something like this?
Unread 20-01-2015, 18:07
FRC #5750
Yes, it does. We have already tried connecting it via Ethernet Cable and pressing the Refresh button to no avail.
Unread 20-01-2015, 18:46
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
FRC #3132 (The Thunder Down Under)
Team Role: Electrical
Rookie Year: 2010
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
Could you please post the output of ipconfig?
Also, try this procedure for setting it up manually.
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 20-01-2015, 19:33
Just Itinerant
Open your Network and Sharing Center by hovering your cursor over the wireless icon on the toolbar or going through Control Panel.
Then go to Change Adaptor Settings in the left column.
That will give you a list of your active network ports.
Make sure they are Enabled (or right-click on each and choose Enable).
Unread 01-02-2015, 00:28
FRC #5750
All our network ports are enabled, and still we are unable to complete the configuration through the FRC BCU. We have all deployed some code directly to the roboRio but are still unable to connect via wireless.
Unread 01-02-2015, 16:39
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Have you followed the advice in the first reply yet?
Unread 02-02-2015, 14:15
FRC #5750
We have tried what Alan Anderson says and it worked. The only problem now is that but it now displays an error when it is trying to locate the bridge at expected IP. We have already tried the solutions listed in the pop-up, but the issue remains. Could someone please tell us what we have got to do?
Unread 02-02-2015, 14:49
Software Architect
...it now displays an error... Could someone please tell us what we have got to do?
You have to tell us what the error says in order for us to know what is not working. Show us a picture if possible.
Unread 02-02-2015, 17:30
FRC #5750
Here is a screenshot
