Go to Post What is this? PVC pirates with no visible PVC? (at least that I can see) IMPOSTORS! - theawesome1730 [more]
Unread 01-17-2015, 07:53 PM
MRT45's Avatar
MRT45 MRT45 is offline
FRC #0253 (Mills Robotics Team)
Rookie Year: 2013
MRT45 is an unknown quantity at this point
Can find the compiler on Eclipse?
After setting up the robotrio and setting up the PC for this year, I ran into this problem in uploading the code. Also, what is different in Eclipse this year for FRC compared to last year's netbeans?
Buildfile: C:\Users\admin\workspace\EXAMPLE_ROBOT\build.xml
Trying to override old definition of task classloader
clean:
compile:
[mkdir] Created dir: C:\Users\admin\workspace\EXAMPLE_ROBOT\build
[echo] [athena-compile] Compiling src with classpath=C:\Users\admin/wpilib/java/current/lib/WPILib.jar:C:\Users\admin/wpilib/java/current/lib/NetworkTables.jar to build
BUILD FAILED
C:\Users\admin\wpilib\java\current\ant\build.xml:6 9: Unable to find a javac compiler;
com.sun.tools.javac.Main is not on the classpath.
Perhaps JAVA_HOME does not point to the JDK.
It is currently set to "C:\Program Files\Java\jre1.8.0_25"
Total time: 1 second
What does this mean? BTW, first timer here....
