Go to Post "The robot is horribly overweight. We need to delete some code" - Dumper FTW 435 [more]
Unread 18-01-2015, 09:41
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
Rookie Year: 2011
fovea1959 will become famous soon enough
Detect missing PCM?
Has anyone hit on a way to determine if the Pneumatics Control Module is or is not on the CAN bus?
Unread 18-01-2015, 10:42
SquishyIce's Avatar
SquishyIce SquishyIce is offline
FRC #1405 (Finney Falcons)
Team Role: Electrical
Rookie Year: 2012
SquishyIce can only hope to improve
Re: Detect missing PCM?
Not sure how to do it through code, but you can check manually through the RoboRIO web app. Connect to the RoboRIO through Ethernet, wireless or USB, then type roborio-teamnumber.local in the address bar, e.g. roborio-1405.local. The web app should show a list of devices connected to the RoboRIO. Hope this helps!
"MAKE IT WORK, DAVID"
Unread 18-01-2015, 11:29
fovea1959's Avatar
AKA: Doug Wegscheid
Rookie Year: 2011
thanks! We're looking to do it in code.
