Go to Post "Is it possible to cut enough holes in the robot to weight reduce 8 lbs?" - ScoutingNerd175 [more]
Unread 18-01-2015, 17:00
tomsgarage tomsgarage is offline
FRC #5230
tomsgarage is an unknown quantity at this point
closed center solenoid valves legal??
We're wanting to design using closed center, three position valves, for double acting cylinders. Anyone know if that might be legal?? Also last year I was thinking that we were required to provide one manual ball valve to release the pressure on everything on the robot. Is this still a requirement - I can't seem to find where this requirement is/was documented.
