Go to Post I swear, sometimes it seems like FIRST has got a room full of monkeys writing code. Maybe the monkeys should spend less time flinging fecal matter at each other and more time testing the code before posting it :-). - Kevin Watson [more]
Unread 19-01-2015, 10:57
JohnGaby JohnGaby is offline
FRC #2102
JohnGaby is an unknown quantity at this point
Eclipse highlighting non errors
I am finding that the syntax checker in eclipse is highlighting errors that do not exist when I compile. For example if I declare a 'Talon', eclipse tells me:
- The type 'Talon' must implement the inherited pure virtual method
'ITableListener::ValueChanged'
- The type 'Talon' must implement the inherited pure virtual method 'SpeedController::Set'
However when I compile, these errors are not actually present. If I delete all of the errors from 'Problems' window, and rebuild, the spurious errors do not re-appear. However if I make any change to the file, they come back.
Needless to say this is quite confusing when trying to fix real syntax errors. Does anyone know why this is happening?
Thanks.
Unread 19-01-2015, 11:22
RushAHead RushAHead is offline
FRC #3103 (Iron Plaid)
Rookie Year: 2014
RushAHead is an unknown quantity at this point
Re: Eclipse highlighting non errors
Try right-clicking on the project and selecting Index->Rebuild from the context menu.
Unread 19-01-2015, 12:01
FRC #2102
Thanks for the quick response, that seemed to fix it.
