Go to Post A robot is replaced every season by the next robot, but a friend, team member, mentor, and memories will never be replaced. - Jverdon [more]
Unread 19-01-2015, 13:17
FireAmpersand's Avatar
FireAmpersand FireAmpersand is offline
AKA: Manning Team Co-Captian
FRC #4627 (Manning Robotics)
Team Role: Electrical
Rookie Year: 2014
FireAmpersand is an unknown quantity at this point
Recycling Pneumatic System
Hey First Members, Our team is planing on using pneumatics for our robot this year. But they use a lot of air to lift. Does anyone have a design/ idea for a air recycle system thats first legal. I was thinking of just using a one way valve off the exhaust to the storage system. Thanks in advance ^_^
Unread 19-01-2015, 13:23
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
Rookie Year: 2013
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: Recycling Pneumatic System
The simple answer is I don't think you can.
R68 Compressed air on the ROBOT must be provided by one and only one compressor. Compressor specifications may not
exceed nominal 12VDC, 1.05 cfm flow rate.
R68 seems to make it impossible for the compressed air to come from any place other than the compressor.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 19-01-2015, 13:36
tStano tStano is offline
AKA: Sparks
Rookie Year: 2012
tStano will become famous soon enough
I believe the physics of this doesn't work. As I understand it, you're lifting with the difference between venting pressure and pressure in the system. In the usual system, your venting pressure is 0(gauge pressure), and working pressure is 60. If you were to put your 60 working pressure back into your 120 storage pressure, your cylinder would be forced the other direction, and if you put a one way valve on it, the exhaust air wouldn't be able to push into the 120 psi air.
You can also think about it in terms of the second law of thermodynamics, roughly paraphrased: "you can't make a perpetual motion machine".
All the energy in your pneumatics system comes from your compressor. If you somehow manage to use your air that has already done work to do the same amount of work again(which seems to be what you're describing), you've created a perpetual motion machine, and should be a very rich man now.
Unread 19-01-2015, 13:40
Rookie Year: 2014
Ok, Thanks for the replies. I will work on a better pneumatic system then.
Unread 19-01-2015, 14:04
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Don't be afraid to use more than one regulator to set each circuit to the pressure it needs. I've even plumbed the return on a cylinder to be lower than the main actuation pressure. You may also consider using gravity or springs to return cylinders, almost halving air consumption for that mechanism.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 19-01-2015, 14:09
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Fire,
Up to this point one way valves have not been legal on FRC robots. You can ask the question on the Q&A though. One way valves or "check valves" may not allow all air to be vented to atmosphere when the ball valve is opened.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 21-01-2015, 19:00
cougarbot cougarbot is offline
FRC #2665
cougarbot is an unknown quantity at this point
We are trying to wire a bimba MRS-.087-B. The wire coming from the roboCRIO has 3 wires (red,white,black) but the bimba MRS switch has a black and red wire. Can someone help us wire it?
Unread 21-01-2015, 19:56
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
The Bimba MRS-.087-B is a magnetic reed switch that wires to the signal and ground pins on the DIO of the roboRIO.
Unread 21-01-2015, 20:00
FRC #2665
Thanks
