Go to Post FIRST is an organization that teaches students that smart is cool. - Warren Boudreau [more]
Unread 19-01-2015, 15:30
Luid101 Luid101 is offline
FRC #3949
Luid101 is an unknown quantity at this point
Red face Linear Actuator Programming Help
Hey I just finished programming the linear actuators for our team but i have this problem. My linear actuators are supposed to lift at the push of a button until it hits the top switch then come down at the push of another button until it hits the bottom switch. All that stuff happens but the code updates the jaguars irregularly. Like update-wait for some time-update etc. I think it might be the way my loop but i am not sure. Could you guys check it out? THANKS!!!
Unread 19-01-2015, 16:08
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Linear Actuator Programming Help
You have a 5 millisecond wait in the "Allows actuator movement Downwards" case. Why?
How are you ensuring that you aren't simultaneously sending two different commands to the Linear Actuator0 motor?
There's a lot of nearly incomprehensible stuff going on at the left side of your picture. What is all of that supposed to be doing? (If it's what I suspect, you can probably replace it all with two feedback nodes and a couple of boolean functions.)
Is all of the code inside one of the timed loops in Periodic Tasks? If so, which one?
Unread 19-01-2015, 16:31
FRC #3949
Ok.The code is in the timed tasks vi. The code at the left side is a toggle switch for the joystick input. If you could show us a better way of coding it we would be grateful! I am pretty new to labview programming so I am not sure if there should be a wait or not, I saw it there so I didn't tamper with it.
Unread 19-01-2015, 16:34
FRC #3949
Unhappy Re: Linear Actuator Programming Help
Oh and I have no idea how to ensure that linear actuator0 doesn't recive two different inputs we could use some help with that too. Thanks!!!
Unread 19-01-2015, 16:46
Software Architect
Is it outside all of the timed while loops in that vi, or is it inside one of them? If it's inside a while loop, which one is it in?
If you can tell me what you want the code to do, I'm sure I can show you an efficient way of telling LabVIEW how to do it. The phrase "toggle switch for the joystick input" isn't enough detail for me to know what you want.
There are specific places for wait functions, and specific reasons for using them. Besides the timed loops in Periodic Tasks, the only place I think I have put them in a robot program would be in a flat sequence in Autonomous Independent (or a flat sequence in Periodic Tasks, but that's a very special case).
Unread 19-01-2015, 17:02
protoserge's Avatar
protoserge protoserge is offline
CAD, machining, circuits, fun!
AKA: Some call me... Tim?
FRC #0365 (MOE) & former 836 Mentor)
protoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond repute
Are you intending to use a linear actuator on this year's competition robot? If so, verify it is using a motor in the table listed in Rule R18. If it does not have one of those motors, it will not be a legal item unless there is an official GDC Q&A ruling that states otherwise.
Unread 19-01-2015, 17:11
FRC #3949
Thumbs up Re: Linear Actuator Programming Help
Yup we are using the Dart Linear actuators along with the Sim motors they came with. They are the same ones in the robot in 3 days build they should be allowed.
Unread 19-01-2015, 21:01
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond repute
Since you're using Jags, would be easier to wire the limit switch inputs of the Jag to the Dart Actuator? Should work even in PWM mode. I know the Ri3d team did the same thing with Talon SRXs (which also have inherent limit switch inputs).
Unread 20-01-2015, 00:16
Zentx's Avatar
Zentx Zentx is offline
AKA: Robert
FRC #3949
Team Role: Electrical
Rookie Year: 2014
Zentx is an unknown quantity at this point
I'm part of the electrical team. I was wondering how you would wire the limit switches to Jags. What we are trying to do is, toggle up and down when we want it to. So if i were to wire the limit switches to the Jags, if it clicks, would it automatically switch directions or wait for the next command? Would any coding be necessary?
Unread 20-01-2015, 23:23
Zentx's Avatar
AKA: Robert
FRC #3949
Rookie Year: 2014
Basically what we want is to press a button and make it go forward until it hits the limit switch, we want it to stay stationary at that point until a command is given to go in the reverse direction where it should also hit another limit switch and stop. Our previous code did not allow us to move in the opposite direction until both switches have been released.
The wires have been already soldered onto PWM pins and connected to the DIO. I really don't want to cut the connections and rewire it to 2 pin connectors to hook it up to the Jags.If anyone has a solution i would be so grateful!
Unread 21-01-2015, 00:09
mshafer1 mshafer1 is offline
Programming Mentor
AKA: Matthew Shafer
FRC #3937 (Breakaway)
mshafer1 is an unknown quantity at this point
I have attached a snippet (LabVIEW generated picture that can be dropped back in LabVIEW to turn back into code) that shows one way of doing this, if I understand what you are saying correctly, you need the linear actuators to stay on their course until either the the driver sends a different command, or the limit switches say to stop. I think I have shown that in this code, if you have any questions, you could send me a private message and I would be more than happy to help you get more figured out.
I attached my original snippet, then realized that I had a typo, when I went back to fix it, I also realized that it could be simplified a little. Using the shift register in this way is really the same as using the feedback node, just that some say that this way is cleaner.
ID:	17915  Click image for larger version
Unread 21-01-2015, 11:27
Zentx's Avatar
AKA: Robert
FRC #3949
Rookie Year: 2014
Thanks For The Code! Going to test it out soon.
Unread 19-01-2015, 17:06
FRC #3949
It was inside the "10 ms tasks" loop but in an attempt to reduce lag I changed the wait time on the timer to 5 ms.
We need the code on the left to make a button on the joystick toggle a Boolean value. Which we will use to tell the actuator to move or be stationary.
