Go to Post anything that breaks a kitbot frame is probably breaking most custom frames of similar weight, too. - dtengineering [more]
Unread 19-01-2015, 16:36
canine505 canine505 is offline
FTC #0339
canine505 is an unknown quantity at this point
PDP Reading Incorrectly over CAN
We are trying to use the PowerDistributionPanel Java class to read the current from the PDP. The Current readouts are much, much higher than they should be, but only on channels that seem to be incorrect at random. For example, the overall current for the board is usually around 30 amps, with channel 2 around 23 Amps. The temperature and voltage readouts seem correct. Any ideas?
Unread 19-01-2015, 16:52
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: PDP Reading Incorrectly over CAN
You need to provide some more information. What values are present for all the channels at any given point in time? What is hooked up to each channel, and what is it doing? Do you have a meter to independently measure the current for a channel you believe is reporting incorrectly?. By itself, a single channel pulling 23 amps while the overall is at 30 amps could easily be done with a motor under load hooked up to that channel, and little activity on the other channels of the board.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Which thread would you like the responses to be posted to?
This one:
http://www.chiefdelphi.com/forums/sh...d.php?t=133169
or this one?
http://www.chiefdelphi.com/forums/sh...d.php?t=133172
Unread 19-01-2015, 16:53
FTC #0339
The values change apparently randomly, and nothing is hooked up to the channels reading high. It should be drawing 0 amps, correct?
Unread 19-01-2015, 16:54
FTC #0339
This one:
or this one?
This thread, thank you.
Unread 19-01-2015, 17:31
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Be sure to update PDP firmware.
Instructions for updating the firmware are here: http://www.chiefdelphi.com/forums/sh...ht=pdp+current
The ship firmware does not zero the currents, so they can wiggle by a couple amps.
Unread 19-01-2015, 17:41
Unfortunately, the PRO user manual doesn't state any expectations for reading channel current.
I would guess that, in this case, this current sensor is essentially floating, which means the value it returns is meaningless. Try putting a breaker in the channels that are reading incorrect and let us know if they are still incorrect. Then try hooking up a low-current device to the channels and see if they still read incorrect. It's just a guess, but I think putting a breaker in will be enough to stabilize the current sensor and give you the expected result.
Last edited by Jon Stratis : 19-01-2015 at 23:23. Reason: iphone auto-corrected "low-current" to "low-cost"
Unread 19-01-2015, 20:10
Jared's Avatar
Jared Jared is offline
Rookie Year: 2012
Jared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond repute
Originally Posted by Jon Stratis View Post
Then try hooking up a low-cost device to the channels and see if they still read incorrect. It's just a guess, but I think putting a breaker in will be enough to stabilize the current sensor and give you the expected result.
Be careful and don't plug a motor straight into the PDB, it'll fry the current sensor!
Unread 19-01-2015, 21:15
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Have you tried this already? It sure seems like the breaker should protect it against over-currenting the sensor, though I don't want to be the guinea pig to prove it.
Unread 19-01-2015, 21:28
ozrien's Avatar
Omar Zrien
AKA: Omar
Do not connect a motor directly to the PDP...
Warning: Inductive loads (motor, compressor) must have a power management device (motor
controller, PCM, spike) between itself and the PDP. No inductive loads (motor, compressor)
may be directly connected to the PDP channels as this can damage current sense circuitry.
Bottom of section 2.2.1 and 2.2.2.
PDP User Manual
http://www.crosstheroadelectronics.c...ol_system.html
