Go to Post If you want to prove your worth, prove it by creation, not destruction. - DanL [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 19-01-2015, 21:39
alopex_rex's Avatar
alopex_rex alopex_rex is offline
Rainbow Professionalism Dash
AKA: Scott Morton
FRC #0830 (The RatPack)
Rookie Year: 2012
alopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond repute
Trouble with ADXRS453 Gyro
This year we're trying to use an ADXRS453 gyro on our robot. (With this eval board.) Yesterday we wired it up and managed to communicate with using the WPILib SPI class. We simply read the sensor data every time TeleopPeriodic was called, and integrated the results to get a measure of our heading. This worked extremely well, as in, the heading would not change at all while the gyro was sitting still, and changed as we would expect it to when we rotated it.
Then we go to work with it today, without changing the program, and it drifts like crazy. (Like, a degree every couple of seconds.) We wrote code to try and compensate for it, by sampling the rate for a couple seconds while it's still, and the values still oscillate and drift while the gyro is sitting still.
In another thread, members of several teams said they had used this gyro with success. Any idea what's going on? Any wisdom you can share about how to work with it?
Ratpack programming lead 2013 - 2015
ἔκλαγξαν δ᾽ ἄρ᾽ ὀϊστοὶ ἐπ᾽ ὤμων χωομένοιο / αὐτοῦ κινηθέντος: ὃ δ᾽ ἤϊε νυκτὶ ἐοικώς. (Ancient Greek nerds unite!)
Unread 19-01-2015, 21:47
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
Rookie Year: 2014
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Re: Trouble with ADXRS453 Gyro
Posting your code would help.
Unread 19-01-2015, 21:50
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Please post your code as you go. We've got a couple of these gyros on the way as well, and are curious as to how to go about computing bias, etc.
Unread 19-01-2015, 22:11
alopex_rex's Avatar
AKA: Scott Morton
Rookie Year: 2012
As of this posting, a little bit out of date, (also generally rough) but here you go:
https://github.com/FRC830/2015Robot/tree/master/util
ADXRS450Gyro.h and ADXRS450Gyro.cpp are the relevant files. The ADXRS450Gyro::Update() function gets called in TeleopPeriodic.
Unread 07-02-2015, 12:03
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
I took the previous posters code and improved it a bit - the drift is more than acceptable.
https://github.com/FRC1296/RHSRobot2.../ADXRS453Z.cpp
Enjoy
Fast, cheap or working - pick any two!
Unread 07-02-2015, 19:31
duane's Avatar
duane duane is offline
FRC #0701 (RoboVikes)
duane is an unknown quantity at this point
Send a message via AIM to duane
Thank you for sharing the code for the gyro. A couple of comments:
You used a Task and Timers rather than a notifier. Seems like a notifier could make the code easier, but there are also two timers which indeed complicate a bit. Are two timers needed? I'd have to read closer to work it out.
The floating point values are floats instead of doubles. Any particular reason? I'm used to thinking of doubles as being just fine for most uses. WPI Lib seems to use doubles everywhere.
The float values are being updated from a task and read from the robot loop. I think a mutex is needed to protect the values being read. Keep in mind that this year, we really do have multiple processors which means we should pay attention to atomic operations. I don't think a double or float is atomic.
This should be great for us to get going with the gyros.
I'll be happy to contribute to any changes we make.
...Duane
ps Gotta luv github!
Duane Murphy
Mentor - Software
Vanden Vikings FIRST Team 701
http://www.vandenrobotics.com
Unread 08-02-2015, 18:32
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
no problem
I did not change the original code all that much. The changes you recommend make sense. One could use a single timer for both the calibration and update functions. I've not used a WPI notifier yet. Is it a wrapper for a counting semaphore? The gyro started working right and I wanted to get it to the students to work on their autonomous behaviours.
I did not think the precision was necessary. One can only "point" the robot with a certain amount of accuracy anyways. Doubles will work.
Floats are atomic as they are word-sized on a 32-bit machine. But a more portable implementation would protect the data - good idea.
good luck!
adding averaging would be nice
ditto
Unread 17-03-2015, 15:29
orangelight's Avatar
orangelight orangelight is offline
AKA: Alex
FRC #0548 (Robostangs)
Rookie Year: 2014
orangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to behold
Does anyone have the source code for java?
