Go to Post You know, I love the fact that FIRST has always got your back. :D - Beth Sweet [more]
Unread 19-01-2015, 21:40
FleventyFive FleventyFive is offline
FRC #4118
FleventyFive is on a distinguished road
Compiling OpenCV from source for ARM (RoboRio) in Ubuntu/Debian/Mint
  1. Install dependencies
    Code:
    sudo apt-get install build-essential
    sudo apt-get install cmake
    sudo apt-get install gcc-arm-linux-gnueabi
    sudo apt-get install g++-arm-linux-gnueabi
  2. Enter directory that will hold opencv
    Code:
    cd ~/Documents
  3. Clone OpenCV from git
    Code:
    git clone https://github.com/Itseez/opencv.git
  4. Checkout to a recent OpenCV release (change 2.4.10.1 to a recent release)
    Code:
    cd opencv
    git checkout tags/2.4.10.1
  5. Set toolchain to correct version of g++ (change line in file or run this complicated one-liner
    Code:
    cd platforms/linux
    x=$(dpkg -s g++-arm-linux-gnueabi | grep "Version" | grep -o ".\.."); sed -i 's/set(GCC_COMPILER_VERSION "*.*"/set(GCC_COMPILER_VERSION \"'$x'\" CACHE STRING "GCC Compiler version"/g' arm-gnueabi.toolchain.cmake
  6. Prepare file for build
    Code:
    mkdir build_roborio
    cd build_roborio
    cmake -DSOFTFP=ON -DCMAKE_TOOLCHAIN_FILE=../arm-gnueabi.toolchain.cmake ../../..
  7. Build project (this will take a while)
    Code:
    make
Last edited by FleventyFive : 19-01-2015 at 21:55. Reason: work for versions that arn't 4.x
