Go to Post I'll give you my prediction in just over 35 hours. - Andrew Schreiber [more]
Unread 20-01-2015, 11:15
waldohatesyou waldohatesyou is offline
FRC #3705
waldohatesyou is an unknown quantity at this point
FRC- Sensor Help
Hi there, i have been trying to code a couple of sensors for our FRC robot.
hall effect sensor and an pontentiometer. unfortunately it hasnt been working; does anyone have any sample code in C++?
Unread 20-01-2015, 11:18
marshall's Avatar
marshall marshall is offline
My pants are louder than yours.
FRC #0900 (The Zebracorns)
marshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond repute
Re: FRC- Sensor Help
You should post what code you have along with how you have the sensors setup physically as well. What specific problems are you running into?
Unread 20-01-2015, 11:19
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Depending on your application, Hall Effect sensor typically uses the counter object in WPILib.
Potentiometer uses analog input.
The more detail you provide, the more detailed the answers you get will be.
Unread 20-01-2015, 11:37
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Originally Posted by Ether View Post
Depending on your application, Hall Effect sensor typically uses the counter object in WPILib.......
Another possibility that goes with "Depending on your application", a Hall Effect Sensor could be set up as a simple limit switch. In this case, it would be a "simple digital input".
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
