Go to Post ...regardless of anything that happens, there should be no booing at competitions, only cheers. True, many of us want to win, but in the end, all of us are working to expand FIRST and to promote the inspiration and recognition of science and technology through gracious professionalism. - Aignam [more]
Unread 20-01-2015, 11:40
Bruno#1382's Avatar
Bruno#1382 Bruno#1382 is offline
FRC #1382
Bruno#1382 is an unknown quantity at this point
problem with driver station
Hey guys
I was trying to test some sensor with our roboRIO but it not communicate with the driver station if i conect via USB directly is comunicates but if i try via wifi it no connect. We tried to use with the cRIO II and it connects same way the roboRIO not
what can I do to solve this?
Thanks,Go#1382
Unread 21-01-2015, 08:36
Re: problem with driver station
My guess is that your DLink has not been updated to turn on DHCP and the other settings that the DS uses to locate the roboRIO.
Greg McKaskle
