Go to Post yes, we've gone over every possible idea multiple times. No, we're not going to stop. Welcome to FIRST. - logicalyrandom [more]
Unread 01-20-2015, 12:11 PM
Awesomegamer235 Awesomegamer235 is offline
None #4607
Awesomegamer235 is an unknown quantity at this point
help on coding camera
if i wanted to code a camera what vi's would i use
Unread 01-20-2015, 01:03 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: help on coding camera
That depends greatly on what you want to do with the camera.
What do you want to do with the camera?
Unread 01-20-2015, 01:51 PM
Infinit3PI Infinit3PI is offline
FRC #4607
Infinit3PI is an unknown quantity at this point
Having been looking at it, we are now attempting to integrate the example or a rendition of the example color and shape processor into the base RoboRIO vision processor.
We are working on getting a working autonomous period through vision recognition on the tote.
Last edited by Infinit3PI : 01-20-2015 at 01:52 PM. Reason: Adding better reasoning
Unread 01-20-2015, 02:36 PM
Software Architect
I think that the answer to "what vi's would i use to do what the example does" is basically "the ones the example uses to do what it does".
Where are you running into problems?
Unread 01-20-2015, 02:47 PM
FRC #4607
Having looked a tad bit harder at the example code, I see where I was misleading myself. I didn't see how I was supposed to blend the two codes together, but it was simply an inability to see the obvious on my part.
