Go to Post Am I the only one who thinks robots are the main attraction of a regional, and there isn't a need for more distraction? - Adam Richards [more]
Unread 20-01-2015, 18:49
YAK'ker's Avatar
YAK'ker YAK'ker is offline
FRC #2192 (YAK Attack)
Rookie Year: 2007
YAK'ker has a spectacular aura aboutYAK'ker has a spectacular aura about
Actuators that are legal for FRC 2015?
I know that FIRST can be picky about electric motors for robots in FRC. We are having difficulty getting 12" Actuators from AndyMark and would like to go with another company and manufacturer. Curious if this 12" Actuator is OK for use in FRC? Seems to be comparable in terms of motor electrical requirements and lift capability of actuator.
http://www.everestpartssupplies.com/...ft-dc-12v-volt
“Wisdom comes from experience. Experience is often a result of lack of wisdom.”
― Terry Pratchett
Unread 20-01-2015, 18:55
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Rookie Year: 2010
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Re: Actuators that are legal for FRC 2015?
You would have to replace the motor with one of the motors listed in Table 4-1 in the manual.
FYI: The actuator you linked to moves at 12mm/second, which is very slow compared to the DART actuators on AndyMark.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 21-01-2015, 05:01
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
+1 on slowness. 12mm/second means it takes 24 seconds to lift a single tote! However, it doesn't list any kind of gearing or anything, so I would contact them. It could just be the stock motor being slow.
You might want to try belts or chain if it's just for a simple lift, or try using just a versaplanetary if it's for rotating an arm. Much easier and lighter than leadscrews or other such actuators.
