Go to Post Woody, If there is any chance your reading this ... you've changed my life. - Gope [more]
Unread 21-01-2015, 07:20
Manah Manah Manah Manah is offline
Manah Manah is an unknown quantity at this point
programming sensor inductive and magnetic encoder??
HI
How is programming the magnetic encoder and the inductive sensor in labview?
thanks a lot!!!
Unread 21-01-2015, 07:41
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: programming sensor inductive and magnetic encoder??
Part numbers would help. What kind of signal do the sensors provide? The answer determines how they need to be wired and how the program can read them.
