Go to Post Woody says that gracious professionalism is "acting how you would if you grandmother was watching you"... some people must have some really crazy grandmothers. (: - Cappeh [more]
  #16   Spotlight this post!
Unread 23-01-2015, 08:30
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
Rookie Year: 2012
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
Re: actuating a brake or anti-backdrive
Originally Posted by notmattlythgoe View Post
We used a bike brake and caliper on our elevator prototype. You can see it here.
Yes but how did you actuate the caliper?
  #17   Spotlight this post!
Unread 23-01-2015, 08:33
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Originally Posted by asid61 View Post
Where is that 20-30lb estimate from?
It's not an estimate. It's just a scenario to illustrate a concept.
Or were you asking why there's a range, rather than just a single number?
  #18   Spotlight this post!
Unread 23-01-2015, 08:40
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Rookie Year: 2010
adciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to all
It's a pneumatic cylinder. You can see it in the video near the disk brake.
Originally Posted by texarkana View Post
I would not want the task of devising a system that 50,000 very smart people try to outwit.
  #19   Spotlight this post!
Unread 23-01-2015, 08:41
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I'm drawing a blank...probably because I can't see what it is we're trying to figure out how to stop moving. Can you post some pictures or drawings or renderings of the robot or design?
  #20   Spotlight this post!
Unread 23-01-2015, 11:34
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
Originally Posted by loafdog View Post
Hi,
We don't plan on using pneumatics on our robot so I was looking for ideas that used something else to control/move a mechanism that would brake/stop elevator.
I was wondering if servos can be used to control brakes or some other kind of anti-backdrive component. Poking around andymark I saw shifting gearboxes controlled by servos for example. I've seen people on CD discuss bike brakes, ratchets, etc..
But I haven't seen anyone discuss how you can implement these ideas. Anyone done this before and have details/pics they can share?
(note, I'm not a mechanical type.. i do software, just trying to get ideas to share with my team).
THanks.
-Maciej
we had success with a "ratchet/pawl" where the pawl was a heavy enough piece of scrap steel on a hinge that gravity lowered it to engage the ratchet, and a window motor pulled a piece of cable attached to the pawl to release it. a window motor hub can be easily altered to actuate a simple switch which would then (after adding some simple code) make this window motor into a sort of binary servo motor.
while mechanically this worked fine for us, cheapfree and simple were two of our main constraints, which may or may not be the case for your team...
