Go to Post Patents are an issue of law which, alas, has little to do with engineering or common sense. - Mike Betts [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Unread 21-01-2015, 12:38
goofy173's Avatar
goofy173 goofy173 is offline
Electronics Mentor
FRC #2867 (ElkLogics)
Rookie Year: 2014
goofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to all
encoders
One of our programmers has heard that the standard encoders are not very accurate. We've never used them for any real reason. Do they work fine for normal use?
Unread 21-01-2015, 12:41
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: encoders
I'd suggest a link or make/model for what you think are standard encoders.
Unread 21-01-2015, 12:54
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: encoders
...and also define what is meant by "normal" use.
Unread 21-01-2015, 14:23
goofy173's Avatar
Electronics Mentor
Rookie Year: 2014
Re: encoders
I found 3 of them in the electronics parts. I assume they came with the KOP in past years. That's why I call them standard.
Not sure the models because I'm not there at Robotics. I think they are all US Digital E4P-250-250-N-S-D-D-B encoder (am-0174). And also the one attached to the KOP item Gearmotor (PG71 gearbox + RS775 motor + encoder) which the encoder is a am-2816a Hall Effect Two Channel Encoder.
Not quite sure yet what speed the manipulator team is going to be running these at. Probably both less than 1000 RPM.
Unread 21-01-2015, 15:01
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
Re: encoders
Properly done, they work well. Properly means the optic wheel is clean & undamaged. The shaft the optic wheel is on needs to be concentric & have very little end float. The optic wheel needs to be tight on the shaft & properly positioned. Other encoders that have their own shafts & bearings are easier to set up & use.
If you don't know what you should hook up then you should read a data sheet
Unread 21-01-2015, 15:10
Ether's Avatar
Rookie Year: 1969
Re: encoders
So very true. The above post is definitely a keeper.
Unread 25-01-2015, 18:25
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
Re: encoders
I have a different question regarding encoders.
Has anyone used a Grayhill 61K128 encoder with the mini-toughbox?
That's what we're planning to use but I notice that it is a *very* tight fit with the body of the encoder right smack against the motor sides. We're using a 1/4" to 1/4" shaft coupling to connect the encoder to the output shaft. I'm tempted to take a file to the sides of the encoder body to see if we can open things up a bit. I'm worried about side-loading the encoder shaft.
Unread 25-01-2015, 18:44
Jared's Avatar
Jared Jared is offline
Rookie Year: 2012
Jared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond repute
Re: encoders
To avoid loading the encoder shaft, couple the two shafts with a piece of surgical tubing with the ends of the shafts inserted into the holes in the tubing and clamp it down with zipties. It works very nicely for misaligned encoders.
Unread 14-01-2016, 09:06
CryptoStorm's Avatar
CryptoStorm CryptoStorm is offline
EIC Tech
AKA: Joshua Stilwell
FRC #5056 (MegaHurtz)
CryptoStorm is an unknown quantity at this point
Re: encoders
99% of the issue people have with encoders have more to do with the physical installation/positioning of the encoder than they do with the encoder themselves. junk data in, junk data out.
